How to adjust 4G92P clutch level height
thomadyeoh
28
503
Hi
I wanted to adjust the level of my clutch pedal since it is too high and not comfortable to drive in the jam. May be I am just not familiar with it.
Send to a mechanic and I was told only clutch using cable is able to do so and mine is using clutch pump so i have to live with it.:banghead:
Any otai or taiko can clarified this ?:adore:
If it is able to adjust, where should I ?
Thanks very much in advance.:driver::driver::driver::driver:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
adjust at the paddle...lying down see under the steering collum
virqai
206
393
1,563
which want to adjust?....bolt 14mm that function as stopper paddle...or adjustble sub from upper clutch pump to paddle?????he..hee..heee....or customize an adjustble sub puller at trans cluch pump???:listen: :hmmmm:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
let the owner test n try which one to adjust :biggrin:
atleast there's something new for them to explore..nothing harm :adore:
Hi guys,
I got this fren's Kelisa and having probs with the power window. Cannot wind down already and both the Driver and Front Passenger power window not functioning. So I suspect 2 probs either the fuse or the connection. I tried to look for power window fuse but can't seem to find any, so it makes me suspect there is no specific fuse for power window for kelisa but rather its sharing fuse wan. Can anybody confirm on this?
