4g92 sohc (4g92p) no ignition problem
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
dammm... all these while repairing other car for friends/family it doesn't create such a headache to me...
but my own car pulak acting up....
the problem is one night while reversing and parked my car at my porch... the engine dies (been hearing rough idling just before that)
car can crank...but no spark coming out at spark plug cable...so confirm ignition problem...
since normally the distributor was main culprit...i've replaced it with recond unit new....but to no available...the car still didnt want to start... (crank but no ignition) fuel,timingbelt, were all good...
so need help here to properly check the ignition source at distributor socket (or best workshop manual for this specific engine to properly troubleshoot).... atleast if confirmed the new distributor also not working..i can head back to the part shop and get another replacement.... (*been googling for such testing procedure of this 4g92 sohc engine but nothing comes up)
for now i'm looking if somebody have spare ecu and distributor for 4g92 sohc lend it to me to test which one was the main culprit... helppppp :banghead::banghead::banghead::banghead:
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
4g92p oso in wira 1.6 rite?
is the ecu easy to remove?
if yes then i cam ask a friend in seremban if he is willing to help as he is driving wira 1.6
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
i think can close the case already...
found proper testing procedure to check the ignition system (distributor) and confirmed that the replacement distributor is faulty....
will get another unit (exchange back) and test later tonight
Nissan Motor Co., Ltd. and Edaran Tan Chong Motor Sdn Bhd will jointly hold the “IMAGINATION FACTORY” design forum at Universiti Teknologi MARA, Shah Alam, from August 3rd to 5th, 2007.
Nissan is the first auto-maker to hold such a dedicated event to share the behind-the-scene works of automotive designers in Malaysia. Conceived as a program under Nissan’s global corporate social responsibility...
