Sound beeping at 120km/h & above
St0rMRiD3R
Aug 5, 2012
22
4
503
SARAWAK
Helo, all sifu. I am newbie in car, please help me out please. I am driving toyota corolla AE110 limited editon and previously i drive reach 120km/h & above, i heard nothing. Last month i found out that my car is "eating" the engine oil so i go and change the valve seal and the problem solve. After done the valve seal i got reach to 120km/h & above. i got heard no sound at all, since last week once i reach 120km/h i heard beep sound inside the car. i have no idea what is it, where is it come from, what cause it and why it happening to my car. Any ideas? Any comment will be appreciated. HELP!!! :adore::adore:Thanks.
ken yeang
6,617
1,327
perhaps its just a buzzer to inform you the speed limit set by the factory.
Import japanese cars got those sound then reached certain set limit...
My fren's Aristo got the sound when it reach 120km/r too. He ripped it off the buzzer eventually
This may be a stupid idea, but can you try clicking shut the passenger seat belt (even if you have no passenger) and see if it stops the beeping. If I'm not mistaken, your car doesn't have the speed bong bong bong noise like the AE86. But if not mistaken you have a seat belt beep warning. Yours might be faulty - old car.
St0rMRiD3R
22
4
503
SARAWAK
Oh? Really? My car has a beep continuous sound. The seat belt faulty? Do you mean the wire of the seat belt or the others? Really appreciate, I will check get back soon.
The seat itself has a sensor to see if there's a passenger. If there is, then the seat belt warning should sound. Just try seatbelting the passenger seat and see if it stops the sound.
If it does, then the sensor in your seat is faulty.
St0rMRiD3R
22
4
503
SARAWAK
I just found out that my passenger(back) seat belt is behind the seat. If i am not mistaken, it is because of i ask the mechanic to change the rear absorber and he forget to put it back in front of the seat. Is it possible for this to cause the alarm beeping? i will get back to him to put the seat belt back to its place. After done i will come back, may need more time cause i am quite busy for this period. Hopefully it will solve this problem. Thanks ya. :driver:
St0rMRiD3R
22
4
503
SARAWAK
hi, i have done the work. i remove the seat then put the seat belt back to its original location and no more beeping sound right now. THANKS. You are the best. :wavey:
Supra_Fanatics
20,673
3,998
Supra_Fanatics
20,673
3,998
Jetta? you never bring how to check?
Problem is that, have to speed up to 150km/h to test! That time I tested also at KESAS, that also not straight enough. The only straight one is the one before reaching HICOM Proton.
Tested, no matter what gear also still got sound. Low gear, 2nd, 3rd and D. With or without ECT on also same.
bro sf,can describe the sound in detaik and where u suspect it comes from?
sometimes its those little2 thing like the plastic underguard.
is yr jetta turbo?
if yes,i sure its not the sound of the intake?
Motorists will soon stand a chance to win an all expense paid trip to the Abu Dhabi’s Formula1™ Race this November 2010 just by fuelling up at Shell! The Shell V-Power 97 Cash Contest will be held over a span of eight weeks commencing 5th August 2010 through to 30th September 2010. In addition to the Grand Prize, there is also RM129,000 to be won weekly from Shell Malaysia with a minimum purchase of RM30 for any...
