Inspira 1.8 4B10 Modification sugestion
DanzEterna
15,911
3,371
www.primeperdanaclub.com
If the engine didn't start when its soaked in water, the block and head still can use aren't it?
Or its just my imagination.
some mechanical parts can be salvaged but need to be reconditioned & its not cheap, for example the turbine if all in the costs could be on par with a used aftermarket unit.
the ecu & wiring can throw away edi...:banghead:
Tsunami is salt water, mostly gone....:banghead:
sohem
72
5
508
1 of my friend blowed his engine block
another engine light will not go off... siput always worn.
So , stick with NA is the best. But power wise.. not sure how much you can squeeze out of it.
I've done most of it except , touching internal engine parts.
Need find johnson retune my mapping ~~
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
haha i think I saw ur pics at Johnson's FB.
Sent from my Lumia 925 using Tapatalk.
ixeo
4,788
3,080
KL, Malaysia
kezman
67
right now i just buy supercircuit xtractor,,and full set exzos from hotbit(mid and muffler)..but xtractor not install yet still looking for heat resistance spray and wanna to wrap before install..
dude, i changed to supercircuit full exhaust system (header to tailpipe) 1.5 months ago and am loving it. can't compare with other brands / set ups (i.e. hotbits) as i've not tried them before. one thing for sure is that my current set up is quite noisy :biggrin:
on a separate note, need advise from gurus here.
my inspira is on coilovers and 18" rims. the last time i checked, my camber reading was -0.6 front and -1.2 rear left and -1.6 rear right. what is the recommended camber setting for aggressive layan corners? and since the rear camber is fixed, should i install a rear camber kit i.e. hardrace?
thanks in advance all!
kezman
67
anyone can help?
anyone can help?
How come its not the same on the rear?
I think -1.5 front, -0.5 rear is good enough for everyday use.
If u are on torsion beam, i see no way of adjusting the rear camber.
On the topic,
i would keep it in NA form as its just my taste. The soul in revving an NA is there compared to Turbo.
No doubt the Turbo is an easier step for more power.
I will get and air filter, full exhaust system.
A pair of aggressive cam, better clutch for better power transfer.
Probably a bigger throttle body, fuel regulator, additional injector if needed.
A stand alone ecu which is useful for future upgrade.
Replace the brake pad with better set and some bar where it needed.
kezman
67
Not sure. Most probably due to the fact that my ride is on 18" and coilovers.
Yea rear can't adjust thus am contemplating of installing rear camber kit i.e. hardrace brand.
not sure abt ur var model but on my waja rear,a camber screw does the job.
the small adjustable arm is for controlling the toe in or toe out.
The Marketplace Top Posts
hi.. sifus.. i would like to know what can i mod for my 1.8 new civic vtec.. ? any suggestions if there's no budget limit.. ? thx.. :)
