Basic Performance upgrade
steven_323f
54
9
1,508
BM,Pulau Pinang
Oil cooler, ATF cooler, thermalstat, manual boost control, oil catch tank, brake overhaul, engine bar, lower arm bar, radiator (coming soon).
This all already done, any other parts to upgrade before go for tunning, so that can get better power.
steven_323f
54
9
1,508
BM,Pulau Pinang
Maybe i save some money and go fo FMIC so in future no need to change again.
stutzedward
3,416
561
Given a choice to choose between steel piping on TMIC vs. FMIC, FMIC is better anytime. Just that if you plan to retain TMIC, then steel piping is a lot better compared to original rubber hose.
The only disadvantage of FMIC is that you get a bit of lesser response compared to TMIC because of the longer route. But it'll be almost unfelt after some time. U'll be smiling during hot days with FMIC.
I told Ah Wah the other day tht I don't really feel the lag of using TD05 + FMIC. He said the lag is obvious, just that I get used to it already, hence I don't feel it. Probably I need to drive one with TMIC again just to remind me of my current turbo lag.
kaninbu
669
104
lag is very obvious compare stock trek but when rpm reaches 4-5.....the g force is damn bloody nice
stutzedward
3,416
561
Yup. Stock setup gives u a moment of G during initial rev but fades off quickly. Modded TD05 will feel the other way. Low G initially but after 4K, it pulls strong all the way.
TD04 gives me as much as 0.72G during take off but that's just a split moment, then it'll drop to 0.3-4G as it climbs.
TD05 will push you around 0.6G during take off but as it climbs, I can see a constant 0.5G all the way to 3 figures speed.
PS: Pivot speed meter has G function.
zaifulaika
Dec 24, 2013
32
5
508
Sifus.... does anyone the code no for ATR fanbelt? Think mine is not the right one... keep on vibrating when drive even after change the tensioner bearing...
Sent from my GT-I9300 using Tapatalk
---------- Post added at 09:11 PM ---------- 6 hour anti-bump limit - Previous post was at 09:10 PM ----------
*know the code no
steven_323f
54
9
1,508
BM,Pulau Pinang
Mine still using stock turbo & cam, so do i really need to change FMIC or TMIC w steel piping?
stutzedward
3,416
561
Stock setups CAN USE FMIC. Evo cams will give u better response and faster spooling.
stutzedward
3,416
561
I am looking more for 265 cos I know the higher the degree, the more lag at lower revs. In other words, we meed to hi-rev to get power. Airtrek is auto, so traffic stop and go isn't very usable here. :)
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
u r rite. but u can adjust ur powerband using slide cam pulley.. u can tune it get more power at mid range.. if u use below 270deg, it is actually aimed for low rpm range like rally car.. their car is restricted to 5500rpm only thats why they uses below 270deg..
stutzedward
3,416
561
Ahh... I didn't know that. But then, 5.5K rpm is pretty high for city use. My current setup, power comes in around 3.5K and I find it just nice. If it's 4K above, it's really not usable for my daily needs. Will consult Ah Wah to see how.
hey guys, i'm looking for a reliable spray/knocking workshop around the klang valley area.
i need the workmanship to be good and fast.
the regular one i WENT to has pissed me off for the last time, they don't seem to care about the quality they produce thus giving me shit everytime. i'm fed up of having to go back over and over again to rectify things that should have been done FIRST time.
i changed my car roof due to the excessive rusting. got it back, it leaked badly during rain...
