Basic Performance upgrade
kaninbu
669
104
1,543
i would like to share some standard performance upgrade on airtrek.
1st stage
1. air intake system - k&n,hks
2. straight 2.5inch inlet exhaust piping wif 1 bullet n s-flow jazma tag muffler with 4inch tailpipe. - hks
3. iridium plugs - denso
4. fuel pump - walbro
5. fuel regulator - work,sard
6. manual boost controller - work,hks
7. oil catch tank - cusco,greddy
8. tuning
this upgrade can push boost to 1.2bar - at least 210whp
cost rm3-4k
2nd stage - turbo upgrade
1. td-05 18g - evo5,6,7
3. 560cc injector - evo5,6,7
4. Front mount intercooler - hks,greddy
5. Wastegate - tial
6. 272degree cams - hks
7. big brake kits - brembo,gto(with such upgrade but still on original brake,u gotta b kidding right?
8. tuning
this upgrade can push boost to 1.5bar - at least 280whp
cost rm7-8k
Cooling system - after spending rm10k u surely dun mind spend another 2k for cooling system
1. aluminium radiator - dnd,forged racing
2. evo front mount fan - td05 housing slightly big n almost touches the ori radiator fan,eventually the
ori fan will melt n lose speed.
3. fan controller - make sure the fan running fullspeed at all times.
4. low temp termostat - ntcl,sard
after 2nd stage upgrade still on stock cooling,i dare say ur trek will overheat within 3 months n it happens to me.
cost rm2k
3rd stage
1. Stroker kit
this upgrade will improve ur hp n torque. at least 320whp
cost rm7-8k
The only problem airtrek can't push futher more because of it gearbox.it is an auto tranny.convert to manual is the only way to push futher to 400whp.
Another way to get a better upgrade is buy an evo9 halfcut n dump everything in engine bay n is cost almost the same price wif no hassle n fun,right?
Personally im on stage 2 upgrades but detune n running on ron95 hp around whp240.
most inportant point is there is no such thing as low fc and high power.
u will only have high fc n high power.
I hope this tread will help anybody to upgrade their 4g63t in future.
stutzedward
3,416
561
Nice details bro... all legit and actual factual numbers! GOOD GUIDE!
I'm heading for Stage 2 soon. Now, still at Stage 1.5. Hehehhee...
kaninbu
669
104
1,543
bro,put sticky so we can move on to more advance performance modification.
Civic Type R
178
21
518
Sarawak
forum.myviclub.com
My 0.5 Stage Honda Civic EG8. . . :biggrin:
1. air intake system - Apex'i Dual Funnel Power Intake
2. stainless steel 4-2-1 header & Jasma twinloop exhaust
3. iridium plugs - NGK Iridium IX
4. plug cable - Arospeed Tri-Core 10.2mm
5. voltage stabilizers - Pivot Raizin Blue+Spark Earth+Spark Type S+Vcapa+Enzo
6. groundings - Photo Conducted 2+1 Alternator Booster & 11 points groundings
Running on Petronas RON95 with Mag1 Premium Fuel Booster. . . Just for sharing only. . . :smokin:
Civic Type R
178
21
518
Sarawak
forum.myviclub.com
Of coz.. Quite a lot for me.. :biggrin:
kaninbu
669
104
1,543
item 5 helps if u got heavy electronic stuff in your car.it increase the voltage tolerance to prevent sudden surge for power craving electronic gadget.in other words is a small fake battery tat only can light up a small bulb for 1-2sec.
Civic Type R
178
21
518
Sarawak
forum.myviclub.com
Not neccesarily on heavy electronics.. It work very good on automatic cars,provided ori vs.. :smokin:
stutzedward
3,416
561
I am not really putting a lot of confidence in those things but hearing first hand comments from you, I think I can try to dive in more. I always believe those gadgets helps, but very very little difference only.
kaninbu
669
104
1,543
yes,very little only.dumping tat money n get the most significant outcome is brighter headlights only.
Civic Type R
178
21
518
Sarawak
forum.myviclub.com
Yeah.. I feel what they say lor,i.e: better & smoother gear changes,firmer pedal,better sound quality frm ICE,better ignition,and of coz-better headlights.. :driver:
kaninbu
669
104
1,543
bro,u sure?rm30k for turbo 2.4 at least haven include workmanship i guess.
Hi bros,
Went to this car service,feels he overdo for me.Just an Iswara
Can I ask if someone does the following for your car check?Did he overdo?
Change engine oil and oil filter
Check your air filter,if black colour will ask for change,else just use air gun to spray some dust out
Check for water level and rust at radiator
Check for water level at windscreen water spray tank
Wipes the engine bay area and spray with air gun to clear some dust
Starts engine and check for engine idling...
