ATF Temperature Sensor Install
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Hi guys. I am getting an ATF cooler for my Persona, sourced and gonna by it. Been wanting it since the first year of ownership.
Because whenever I go over 4000rpm during a hot day, it will rev another 200rpm just to change from 3 to 4. Not sure torque converter is slipping or the gears are.
Now, I was thinking during the process of fitting the ATF cooler, I wanna install ATF Temp Sensor simultaneously. Found a few on eBay, free shipping as well.
I am hoping not to drill my oem magnetic ATF sump nut. And drilling my ATF pan is out of the question as it is 10+ bolts away and very hard to reach.
Later on, I will do coolant temp as well but I got that figured it out.
These are ranging from -50C to 125C which is good enough, max is 150C.
If there are any cheaper or equivalent alternatives, please do say so.
Let me have a look at what the ATF sensor looks like. Maybe can retrofit onto the cooler itself.
I think if you can find an adaptor you probably could hook it up to the output hose of the gearbox. Or just buy another size 14/17 bolt with the same thread and drill it la.
stupidcar
5,000 RPM
5,567
850
Like this?
in the picture doesn't look like the tubing have any thread on it. can opt for this type
Heat & Oil Resistant Cable Glands
Bro, I don't quite understand this but I know some sensor act as the plug.
But idk how to find it. Do u know what its called?
Btw, anyone knows whats an ATF hose size? Or specifically Persona autobox
ken yeang
6,617
1,327
Haha I like numbers lah. I wanna monitor it. Its a self-satisfaction to know how my car performs.
if all hardcore, should have install a cooling fan for the ATF cooler.....Sure WOW factor one....:adore:
If fit fan, then need the temperature gauge as over cool also not good....:biggrin:
---------- Post added at 07:59 PM ---------- 6 hour anti-bump limit - Previous post was at 07:58 PM ----------
Where it is fitted will show different temperature, right?
stupidcar
5,000 RPM
5,567
850
Cooling fan is too much for me. Too cooling later shifting also shit.
Natural air cool is enough for me.
Yeap. They usually put at the pan.
Im thinking of putting before the cooler. Just like coolant temp.
Passionate about your car? Would you do almost anything to keep your pride and joy immaculate? If so you're going to love what's in store for you at Auto...
