ATF Cooler (need info)
wfhan
4,339
96
selangor
1. How does this ATF cooler work ? isit same concept with normal oil cooler?
2. Can we use normal oil cooler to be use as ATF cooler ?
3. does this ATF cooler really usefull in M'sia environment and weather? if yes, in what sense ?
4. Where to get ATF cooler in KL/sunway/puchong?
acbc
4,615
8
KD
1. The number one killer for A/T cars is heat. An ATF cooler is designed to prevent a major heat build-up for the A/T box. Concept is similar to engine oil cooler.
2. Yes. I'm using VR4 engine oil cooler for my A/T box.
3. Yes. Definately since our country is quite HOT!
4. Just visit any chop shop.
What car are u driving?
^6A10^
9
yaa.... i also using ATF cooler.... new one
before this.... my automatic gearbox burn (clutch) because of overheating..... :emoticon_U: actually 9/10 automatic gearbox failure cause from overheating.
Max. temp. for ATF is about 80C...., but existing cooler normaly share with radiator... but it is not enough.... especially if u like speeding
He.... he.... now i can drive my car 180++ without any problem.... :shades_smile:
Realz
8
Then if mod in the big oil cooler to std car...the auto transmition will run smooth then std?
wfhan
4,339
96
selangor
i'm driving seg + 4age auto
what oil / fluid is inside tha atf cooler ar?
acbc
4,615
8
KD
Normal ATF. I used Toyota Dextron 4 which is darn good! Can't Dextron 3 because my gearbox will slip on boost.
riz2005
117
malaysia
any oil cooler u can make it atf cooler. i had used pajero oil cooler for atf cooler. its big than gsr oil cooler. but i was change my GB to manual so no need to use this. i think i wanna sell it laaa... i use it just for 3 month.. buy at chop shop
wirafly
958
I am using ATF Cooler in my GB, no more cluth slip or GB behave weird weird during hot weather especially hot weather traffic jam
wirafly
958
brother, how much u got urs brand new ATF cooler?
popcorn
406
how much to install this ATF cooler + labour charge ? any recommended workshop ?
normality78
3,052
23
5,138
JB
basically just go to scrapyard and look for pajero oil cooler. price vary frm diff states. should be rm80 onwards (i get mine on rm80 last time)
try not to go for too big. bigger doesnt means better as u need to take in consideration of oil pressure drop.
Labour charge, all workshop again is diff. i think should not be more thn rm80 also. just re-route the hose and mount the cooler bracket only. most of the workshop can do but which does the best job thn u sendiri pandai pandai.
make sure u flush the cooler before using it. coz those r engine oil cooler but not atf oil cooler.
wfhan
4,339
96
selangor
normality, how to flush the used pajero oil cooler b4 use it as atf cooler ar?
use what fluid to flush?
RERider
2,756
104
3,163
Putrajaya
I heard M-Scope in Bt Caves they are doing the auto trans oil cooler. Also anyone here has noticed the latest batch of waja and perdana (from 2006) has come with AT cooler? I think proton has realised that why they need AT oil cooler. Too many transmission failures in the past, many waja and perdana owners encountered this issue.
acbc- how much the toyata Dextron 4 cost u?
Cheers:_:
normality78
3,052
23
5,138
JB
flush with ATF fluid of course
normality78
3,052
23
5,138
JB
Cheers:_:
If the latest batch did come with the ATF cooler, that would be great for us too as we've got more scrap or used cooler to look for in the market. whahahaha.
so far, i think Hayden one is the best u can find in Msia but to some plp it tends to be more ex coz with scrapyard pajero one can be found as low as rm150, paying rm300-400 for a brand new Hayden ATF cooler seems to be heavy. However you must see the built quality and there are differences between ATF cooler and oil cooler as ATF cooler fins is more narrow and fine.
The Marketplace Top Posts
i just get atf cooler..but dunno how to install it..can teach me how to install it??..my car is kia spectra
