owners club kancil..
Jul 10, 2013
4
perak
when it comes to kancil turbo there is only 1 sifu that is sifu papagoines
haha cabut...:driver:
if not mistaken L2s halfcut with bodypart is rm3-3.5k..forget bout using l2 bodypart la its similar to kancil.
my kancil bodypart already got kemek2..if l5, cute, but will be aim with jpj later on :bawling:
4gbanger
1,958
386
1,683
Johor/ShahAlam
hi guys, i'm looking for a kancil without engine and selling very cheap (valid geran) for my transfer project. my kancil is burned the whole rear after SNF 2011 and roadtax have not been renewed after that. i'm looking at rm 1000+-.. thanks guys
yh4everlim
42
5
1,508
Selangor
im driving a l2 turbo after chg to big turbo wanna install FPR but i heard ppl saying l2 fuel rail cant install and 1 of my l2 fren say his car the machanic weld the fpr to his fuel rail.. anyone did install FPR in l2 before can share??? tqvm
4gbanger
1,958
386
1,683
Johor/ShahAlam
i install FPR to my old kancil.. either way is ok.. the stock regulator only regulates on certain level of pressure. install adjustable FPR will increase the pressure more than stock. i did both of the way last time with my kancil but no big different.
if u install FPR with stock regulator, u will have safety so when your FPR kong u still have stock regulator (ori FPR rarely kong). If u cut & weld the fuel rail, no safety but better reading of FPR gauge. Or maybe u can go get WORKS fuel rail instead bro? :biggrin:
yh4everlim
42
5
1,508
Selangor
so the fact is i hv no choice to use back ori fuel rail unless i weld a adaptor for aftermarket FPR..
thx for ur info n u mention no big different in performance? the reason i wan install aftermarket FPR is when i boosting 0.5 and push it to 0.9 i felt only slight different in power output.. dun feel like high boost. i assume its de fuel pressure...
one more thing u mention u did it like maintaining the ori FPR with the aftermarket 1.. that possible??
4gbanger
1,958
386
1,683
Johor/ShahAlam
yup it is.. because aftermarket FPR can be linked after stock FPR. Stock FPR situation is at the end of the fuel rail. the stock FPR has a return to tank hose. so instead return straight to tank, link it to aftermarket FPR instead. so, aftermarket FPR can regulates amount of fuel return to tank thus it will increase the fuel rail pressure. correct me if im wrong but thats what i learned the hard way.. :biggrin:
can share ur engine spec bro?
Supra_Fanatics
20,673
3,998
Ya look similar but slight different.
Maybe can just replace the front bonnet for a flat look xD and the bumper with signal lights. Also Fender is different haha! Maybe just convert skirtings
Rear bumper I like this
flamefox850
590
2
5,018
Pasir Mas
www.geocities.com
for stock turbo, stock intercooler and below 1.0bar, there is no need for you to install aftermarket FPR. but if u insist to install, maybe thinking of future upgrade, yes, u have to cut the attached stock FPR on the fuel rail and disassamble any stock FPR parts in the stock fuel rail. depends on your FPR design, i choose to weld nipple to stock fuel rail and attach a hose to the nipple to my new aftermarket FPR
hi bros...
need some help here...last week just change to 15 inch rim from standard 14 inch...the problem is the whenever I brake from speeds of 60km/h or above...my brakes become shaky mcm tayar tak cukup angin ...my padel pun shaking like hell...apa cerita hah?
i ask a few workshop and they say either 2;
1) put a spacer con in the middle of the sportrim hole (but must custom made coz the gap is sooo thinnn)
2) change the tyres (currently on sime tyres)
fyi...this did happen with...
