DIY LED brake lights. Need help.
Supra_Fanatics
20,673
3,998
Not gonna do that.
Need other things weh.
I only do normal functioning lights.
Ya get Knight Rider light + talking Alarm! Damn! Your persona is Knight Rider car since is black
haha! :top:
shiroitenshi
3,676
170
U laugh now, when i do u will see nice.
Muahahahaaha. I ain't go no lala taste man
its not about lala taste la. I did it just to learn lol. My car LED bulbs all bought one. SMD type led difficult to solder
Told Izso to close this thread but he haven't haha.
Soon, ordered my red led diodes from eBay.
200pcs for RM23 only. :biggrin:
Will post pictures ltr with instructions.
As I told you dude, that's not how we do things in ZTH. You figured it out, share la. You don't have to share the technique or the know how but show your final result la.
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Let me help you a bit here la since I've done my own DIY LED 3rd brake light
No.1 you need to find out below
Vs = 12V DC
LED Fv
Normal red ones are 1.9 to 2.1V
High Output about 3 to 4V
mA you intend to supply to the LED 15mA or 20mA higher the brighter but I will put 20mA the max to preserve the life span of the LED
How many LED you want to put in the strip.
Only then you calculate the resistor you need to use. If say you calculated the Ohm to be around 566 or 745 Ohm get the higher than the ones you calculated. 566 you get 600 Ohm 745 you get close to 800Ohm. Also do look into the Watts of the resistor 2Watts is enough for me
My suggestion is that you do all the drawings and calculating on papers 1st before moving to actual project. This is how I do it. You also need to take into consideration the wiring of the multiple LEDs. If wiring multiple LED best to use parallel because if 1 burn others will still light up. If use Series, 1 burn the whole line of LEDs will not light up.
In the below pictures, you will see I'm using parallel series for the entire circuits and I use minis series circuit for each group so if shit happens only 1 group of the LEDs won't light up the rest will still continue to light up.
If I wire all in series, it will draw more current from the source and heats up the wiring because of more current flows. Parallel on the other hand will make all the LED take the same voltage after the resistor and current is spread evenly across all LEDs. This also depends on the individual LED tolerance to voltage variance.
For Knight Rider, not that complicated if you know how to do it. Just go get a running light module and hook it up.
My previous DIY
1st draw out a plan of attack and calculate
2nd fabrication phase
3rd testing and assembling
stupidcar
5,000 RPM
5,567
850
Vs = 12V DC
LED Fv
My previous DIY
I saw urs man. But 3rd brake lights are still okay.
How about the normal brake lights?
When brakes are applied it become brighter. and so on.
When I got my stuffs dy, gonna experiment then.
Dear Sifus,
My car has been vandalised with spray paint dis morning. and its barely 1 month old!! :bawling:
I wonder if any sifus out here can advise on the correct method to remove the paint without respraying the whole car? it has never been waxed nor polished before, just the fresh coat of paint right out from the factory.
here's how it looks like...
