Satria alternator problem
andlfloh
23
1,503
Have had to change the alternator twice within a year. I am told the expensive original alternator also does not last. Am advised to get a used Japanese one from a half-cut shop.
My Satria is 1.5 auto UK specs. I changed to ngv some months ago. Does the extra heat from using ngv affect the alternator ?
It shouldn't. In fact original alternator should last you a good 3-4 years minimally. How did the old ones spoil? You can opt to just service the thing by changing out the carbon inside. Much cheaper!
andlfloh
23
1,503
Have started using ngv 6 months ago. May be the heating affects the alternator. The recond one doesn't last.
I have a friend who's on NGV for his Satria as well but he doesn't have the issues you have. If you think it's the heat, try making a makeshift heat shield using some alu foil and hard plastic/aluminium sheets and protect the alternator and see how it goes?
Original alternator for my car also very expensive. So I tried chop shop ones, lasted only 2 weeks, 2nd unit one month, then went for recon, lasted 2 to 3 years. Slightly more expensive then chop shop ones only....
all depend on luck.....by logical thinking i prefer the halfcut unit one.....
last resort only go for recond unit because the risk % of kong again is higher... :adore:
I also went for half cut first, but unlucky maybe because one only 2 weeks the other 1 month, but recon a few years.....
actually the 1st unit i got from halfcut didn't even work at all....(offcourse i tested with multimeter to confirm this)
so the next day return and got another unit..then only it works untill now...
I wanted to install an amp which stated that the voltage supply cannot exceed more than 13.5vdc.......... In car the voltage can peak to 14.4vdc.
Anyone out there can give me any suggestion how to maintain my car voltage between 12vdc to 13.5vdc?
