Drive a Honda Civic Eg/EK Must Read!
E-Tech
1,115
256
3,183
Johor
thx for yr fast response.
if remove J1, there is solid (no error code) the CEL won't go off but the main relay was clicked after 2 sec like normal.
i run p27 on D16Y sohc (non-vtec)
i hv run out of idea how to solve this.
Car can start but how is the idling?
Can rev pass 3500 rpm?
shiroitenshi
3,676
170
Bro E-Tech, on PT2 Accord ECU, where is the IC17 located? because in this ECU, layout totally different, so I can't find it. But tracing from A7, followed it to ZQ17.
Just want to confirm before I solder in a replacement.
E-Tech
1,115
256
3,183
Johor
Sorry no PT2 onhand to confirm but is zq17 TA8903SN? Yes then shoud be correct.
shiroitenshi
3,676
170
No, this board doesn't use the TA8903SN power supervisor ic.
In fact that was the component i looked for first before tracing the A7 back to ZQ17.
The board has nothing in common with the normal P08 b/d series ecu.
Just though i'd try fixing it since encountered the same problem before in B/D series ecu.
Its late, so i guess i'll try checking the part to see what it actually does tommorow. Thanks for the reply.
E-Tech
1,115
256
3,183
Johor
1. there are rough idle.
2. have not tried yet, i think it can't pass 3500.
thx you..
You hv a broken connection sonewhere....u need to check back all the areas you have done work on.....
thinnaph
Jul 12, 2012
5
bkk
Not solved yet, still got solid cell. :bawling:
double checked all trace again, not see any abnormal.
can you specific the area that i have to inspect?
note that the P27 ecu is quite same as P28 but it is no VTEC.
Big thank.. e-tech
E-Tech
1,115
256
3,183
Johor
Big thank.. e-tech
Bro...
Email me some good pictures...
[email protected]
spoon civic
403
36
terengganu
Hi all...
Hope this scares'' you so that you will take preventive action before it happens to your ECU.
If you drive a civic EG or EK most possible you have a ECU in your car with the code P27, 28, P08, or P30.
I have repaired about 10 honda civic ecu with this type of problem..
This write up is on a ecu P30 which I had to repair for a friend's workshop customer's car... last saturday nite...
Lucky it was detected before any major mishap occured... A capacitor (C27) in the ecu leaked and cause a short burning a hole in the ecu..
Pls see attached picture for clearer info and take action on yours.... TQ and do thank me too.:biggrin:
one question,if this part problem..what are the eccfect while we are driving?or maybe check light engine will on at tachometer?or engine knockign or what sym[htom that we can detect this capacitor problem?
---------- Post added at 01:14 PM ---------- 6 hour anti-bump limit - Previous post was at 01:14 PM ----------
Hi all...
one question,if this part problem..what are the effect while we are driving?or maybe check light engine will on at tachometer?or engine knockign or what sym[htom that we can detect this capacitor problem?
E-Tech
1,115
256
3,183
Johor
Actual worst case senario... big cap leak and short or circuit broken.... becomes hot and burnt a hole
on the ecu pcb. Car stink from the smell of burnt pcb. Car cannot start.
Others will be like poor idling or engine check light comes on....
Oct 9, 2012
2
I have experience quite same case for my P30 | ECU. The capacitor leaked and the trace is burn. This cause vtec sometimes on and off. My friend help me replace the cap and luckily it still works.
It was my friend's car. Happened at Hartamas. The funny thing is, the thief stole the cd player and lcd. Smart tag still there. The weird thing is we dunno how the thief broke into. Glasses are all intact, no scrathes on the car and no door was broken. We even open the door using the remote. :-?
