4G63 evo3 upgrade
are_cap
187
4
hi all,
just want to ask ur suggestion regarding 4g63 stock engine want to upgrade to best performance but still can use on the road.
can u all share what is the best "recipe" for 4G63 evo3.
now my car jemrod already so donow want to upgrade or still use stock item (blur2) :banghead: ..hahaha.... :adore: :adore:
BadBlakie9136
Jun 28, 2011
37
its all up to u bro..if u wanna upgrade..then go ahead..if jz wanna maintain stock engine..also ok..coz evos engine's performance in stock is alredy enuf..
if can ask ur self what u wan, then plan and take the right way..and neva look back..cheers..
mospeda353
689
34
3,028
depends on $.. 500hp oso can be daily car.. recipe? :listen: strong bottom, gud fuel system, tough drivetrain, big turbo, management..
DanzEterna
15,911
3,371
www.primeperdanaclub.com
just get ori tonka banana, turbosmart wastegate, ori ssqv 4 from japan, full ss piping for intercooler, air intake etc...
skyline GTR intercooler....thats enuf....
thats for stage 1 le....
if u want stage 2 or 3 i can list for u....depending on yr budget.
jinkl
4,624
376
3,183
my suggestion
1. 3 puck clutch
2. decent BOV
3. upboost to about 1bar
4. decent piggyback
are_cap
187
4
guys if i wanna upgrade to 2.2L should i buy stroker from 4D68 right?
if i use crank and rod from 4d68 at my stnded block can hold the power or not?? and 1 more thing if i use fairlady piston it's strong enuf for street use?
advise pliz..
ah_man04
31
Standard block shouldn't be any problem for using 4d68 conrod.
Regard fair lady piston, no problem for street use, just that the compression is low,
Mine car had used quite sometimes..no issue. Well, ppl now suggest using 2j piston, cos higher compression.
Sifu, any recommendations for piston choice ? Tq
ah_man04
31
aiyaaa..oledi use fairlady piston la bro..how? still can use right?
Sure can use lah...personally I think depend on how many
Whp u wish to achieve.
Sifu situ, I have a question, with these setup, the highest boost we can go and not harm the engine?
Stock evo2 head, block
Fairlady 87mm piston
4d68 conrod
ACL racing main bearing
The current compression is about 10psi / 150 (sorry that I am not sure about the unit,
Pls correct me if I am wrong )
huakenny
LB Performance
9,126
240
Kota Kinabalu
my current mods :
1. Evo 3 with 2.3L tomei stroker Kit
2. Power Division Balance Shaft Kit
3. Fluidamper crank pulley
4. Power Enterprise Kevlar timing belt
5. 70mm throtle body wit stock throtle manifold (port n polish to 70mm to match d setup)
6. oversized 1mm valves + port n polish head
7. Power division S2 camshaft + valve spring set
8. Uprated HLA Pressure Regulator
9. Mines Ecu + M7 em-com piggyback
10. HKS Racing blow off valve
11. Trust Turbo inlet pipe
12. HKS intercooler and intake piping
chassis etc:
- front and rear subframe fitted with racetech C.A.K 12pcs
- front and rear Endless brake pad with uprated disc rotor
- APP Brake braided hose + AP Racing brake fluid
- Braided clutch hose + AP Racing Fluid
- Race Tech Brake Stopper
- Evo 3 full set AWD Drivetrain/axle
- Cusco front and rear upper strut bar
- HKS Catback + FGK Downpipe with cusco exhaust rubber
havent install and buy is
1.clutch
2.turbo(currently got td06-24g with 7cm2 housing...seems not enuf i think)
Planning to :
- install surge tank with additional fuel pump
- Superpro rear differential n frame bushes
- DSS uprated propeller shaft
doing this car slowly at shop now, hopefully it will be fine/fun to drive
my target 400-500hp
jinkl
4,624
376
3,183
my current mods :
chassis etc:
1.clutch
Planning to :
my target 400-500hp
sweet setup , the treadstarter gonna scratch his head la bro
Got this info from a friend's FB. For those who lost their beloved ride you may proceed to Seri Kembangan Police Station for further info.
EK - WEN325
EG - KAW6232
EG - BEX5665
EG - WEP6213
17x Hondas & 9x Turbos without reg plate.
Cheers...
