1JZ VVTI users
stepwyew
448
15
your pictures showing 1JZ-GTE and not 1JZ-FSE.
1JZ-FSE is the 'economy' version (eg.3SG v 3SF)
If running well why want to change manual gearbox or mod some more???
Hello Uncle,
People just want to fine tune the ride only mar ....cannot meh ?????? you also mar fine tune your ride .....like Your ride already very fast in standard stock and yet u still want to boost it , dont know what blady ecu you replace so that can exceed 180km/hr, hahahahahahaahaa .... tyre already so
good and really bite the tar road and yet you go change to dont know what RE bla bla bla
hahahahahahahahahaha
Cheers Uncle :cheers:
:fight::fight::fight::fight::boxing::boxing::boxing::boxing::party::party::party:
icon86
117
5
3,018
Klang
I showed the 1JZ-GTE picture because we are comparing between the JZX100 & JZX110 not the FSE
---------- Post added at 04:55 PM ---------- 6 hour anti-bump limit - Previous post was at 04:50 PM ----------
perhaps want to put 1jz vvti turbo in the future? :P
Yeah perhaps.... That's why I'm asking all taikos & experts here...
but which will be the one? JZX100 or JZX110
1JZtezza
371
42
Hello Uncle,
What talk you???? tyres botak lah!!! NEED to change.Where got boost like you some more where got so many gadgets like you!!!!:confused::confused::fight::fight:
:listen: tune the right foot; then pedal to the metal and break your GPS record OK!!!
---------- Post added at 05:11 PM ---------- 6 hour anti-bump limit - Previous post was at 05:08 PM ----------
FYI: 1JZ-FSE never came with manual in the JZX110
maybe Japs have reason?????
stepwyew
448
15
The record in the gps hard to break lah uncle ...... Event I fine tune my right foot but eyesight not good susah lah hehehehehe
:driver:
ALT3224
59
1,508
any thoughts on whether it would be feasible to get a manual half-cut 1jz now to restore/tinker about for future use, i.e. just take out the engine and refurbish it without using in a car? supplies of 1jz should be dwindling soon...
Bl@cK-TeZZ@
837
6
:driver:
Steven, u pinjam me ur gps for a day to work. Guaranteed the record in gps sure break one! .hahahaha.
1JZtezza
371
42
Austin,
sure lah captain you put in cockpit of your plane!!!....no fair like that.
Like that steven drive veyron also cannot break!!! hahaha
---------- Post added at 09:35 PM ---------- 6 hour anti-bump limit - Previous post was at 09:21 PM ----------
problem is storage!! and you also need to choose carefully...usually 2 weeks after purchase recond shop forgotten already....caveat emptor!!
If you put under the bed....lagi cannot sleep hahaha
wfhan
4,339
96
selangor
so.. if i want a near-to-perfect plug & play 1jzgte dual-vvti into altezza,
i should target those from jzx___ which code?
ALT3224
59
1,508
storage not a problem, and since it's half-cut bound for refurbishing, some repairs are expected. also more the reason to find the better ones faster before all gone...
if not mistaken, for 1jzgte with vvti, only JZX100 and a few JZX110 has it...JZX90 is the twin turbo non-vvti 1jzgte
stepwyew
448
15
Austin,
wah....uncle bully small boy yeah........fine .........i ll wait u in bukit putus this week end
hahahahahahahaha
Sil80-13
1,215
44
1,648
Hi all sifus,
Thinking of getting a Altezza & plan to transplant 1JZ VVTI turbo on it. Need you guy's information on below.
1. Is the engine mounting all plug & play for 1JZ conversion? Or all engine mounting need to modify?
2. Is the gearbox plug & play or need modification?
3. How about the real axle? Need to modify or plug & play?
Thanks...
green
326
25
3,028
kl
ehh... not so simply la. all also need to modify. especially wiring. wrong wiring...pus!!! thr goes your electronics
good luck
stepwyew
448
15
yes , the wiring is very complicated and is not easy , must have the diagram , even if you have it must need a very experience wire men to understand the icon and the colour code .Mine is JZX171. JZX 100 and this JZX 171 the different is the throttle body . JZX 171 is DBW, where else the JZX 100 is not DBW.
As for the question 1 n 2 , some use JZX 100 mounting and some use altezza mounting
Gear box is just relocation only and rear axle some use bk altezza and some use JZX 100.
For your info , is not easy , so , you plan well before you transplant .
cheers mate .:beer:
1JZtezza
371
42
Lengthy reply (by his standards) by uncle stepwyew.
A few claim easy-easy plug and play....not soooo
Heed the words of taikor stepwyew.....
guest
346
20
Kota Kinabalu
hai guys..im not a toyota user but i would like to know beside 1jz,2jz...can altezza swap engine to 3sgte turbo?i find from the internet that need some modification? orientation of the engine?can any of altezzarian clarify?
guys.. need your help and opinion..
can fto dashboard fit satria or not? have u heard about it? ok or not ??i heard that evo4 dashbord can fit wira with some mod..but how bout fto... i want to try la...:shades_smile:
