L2 / L5 Ecu mod- No Boost cut
Newbienissan
Banned
Jul 19, 2010
279
17
earth
other than this, adding additional vacum valve, T-joint....can also do the trick. it is a way to "cheat" the boost sensor that you "did not" reach 1bar. Proof to be able to boost up to 1.5 bar
E-Tech
1,115
256
3,183
Johor
Wrong way= car will not start
Correct way= car can start
50-50...
VeaRN
Oct 12, 2010
22
503
Kota kinabalu
I havent install any turboed engine yet... i'm just curios :embarassed: (planning next year, coz car still on loan)
Thx for the reply though
E-Tech
1,115
256
3,183
Johor
Seach my postings.... you will find the answer here in zth. (daihatsu/diy forum section)..
tq
sideksepakragabulat
Jun 28, 2011
37
508
hi there,
i was using an one way valve to eliminate my boost cut before..internal part was standard only upgrade 240cc+4g93t fuel pump and a FPR..boost 1 bar at this time..
now i'm using an oversize piston+safc..before using safc fuel press is around 3 bar and the car feel smooth at all range of rpm..nowadays i have to set around 70 psi(5 bar) just to get afr around 12.22 and boost around 1.3 bar..if i disconnect the one way valve can the fuel press set a bit lower?can i still boosting more than 1 bar after removing this one way valve?i'm planning to change the tebo and up boost to around 1.5-1.7 bar..can this be achieve just by changing to a much bigger injector and fuel pump?also planning to use a gsr injector(390cc) for this target..
the main question is can i remove the one way valve and still hitting more than 1 bar just by using a safc and bigger injector?
penagihdadih
117
17
Shah Alam
hi there,
removing one way valve on your map sensor will not effect your afr by much. changing to bigger injector will have a better result. 390cc with safc can boost more than 2 bar if you get the tuning correct. would recommend you to use 310cc injector.
Sepang International Circuit is about to be abused this weekend, not to say it has never been abused before but this time around, it will be abused by supercars that are out for a greater cause, to rebuild and restore communities ravaged by the recent floods here in Malaysia. The clubs of supercar owners have organized a “thrills at Sepang” event to raise awareness and funds to aid flood victims...
