K3-VET/YRV vs Bolt on Turbo
Furai
5
1,508
I am sorry...but i have to correct you...
What makes you think the piston bore of a Turbo R is any bigger than...What do you mean by coil?K3 are running on direct ignition....
and all K3 has the DVVT coil...just bukak ur valve cover and see...
Speed cut? japanese governement has the regulations of restricting it...unless the halfcut is obtained out of jap...maybe Russia or singapore....
2 x o2 sensors? normal k3 has it too..even NA....
and think logically...what makes u think DAIHATSU will spend much more money on doing R&D for another base out of K3 but just calling it Turbo R...?
The main difference is the ECU...the fuel mapping in the Management is different...
at most daihatsu will play with compression...just like K3VE and K3VE2...they just raise the compression of the piston and change the ECU mapping...and there you have an engien with slightly higher output.....
---------- Post added at 03:15 PM ---------- 6 hour anti-bump limit - Previous post was at 03:11 PM ----------
Bro, between BOT or K3vet halfcut...i would go for halfcut..and maybe can kahwin with your k3 manual gearbox..
BOT is a fun process...but the tendency of going wrong is high...for a problem free solution...go get a K3vet halfcut..drive it stock...and its problem free..toyota/daihatsu engines are pretty reliable....when stock...
btw...there is another option since u are driving a myvi..get a 3sze....1.5 litre...same engine as alzas....
i would prefer CC...as there is not replacement for displacement.. cheers :rolleyes:
I am one happy owner here...with manual tranny boosting at 0.9 stock boost..
Do you know much does an alza half cut cost nowadays?
May i know your WHP ? since you already have experience running on o.9 boost. thanks :)
---------- Post added at 01:12 AM ---------- 6 hour anti-bump limit - Previous post was at 01:10 AM ----------
diu , pening2 for that SPecial edition or Type R Edition for wad
Since u say UNLIMITEd Budget:
if want power
1. change Rebore piston
2. LArge intake manifold + throttle
3. high cam + adj pulley
4. exhaust banana
5. standalone / piggyback tuning
6. Clutch Racing 3/4 Puck
7. Cantik punya Amoi .
walao how much would all of that costs?
szeeonn
131
10
dun diu them , u tot 1.5 engine easy find a ?
better change internal parts lar
change realistic thing
For the psrts i say , all depends on u
if u unlimited budget can do all of it
but i prefer the Amoi parts . it is FREE lol
Furai
5
1,508
what do you mean by amoi parts?
Turborized
138
19
Im driving myvi yrv now and i would suggest you to get yrv better than BOT-ing your car. like jun_ng_1208 said.
YRV halfcut market price is around 5k - 5.4k only. and dont bother getting the 4wd, you would be wasting your money changing it to 2wd. just a small problem that most myvi yrv problems have is the gearbox would drop, IF you use the triptronic g/b.
Like me i used back my M/T trans back, but theres no more triptronic.
my car stocked dyno 137 hp.
DJgErM
4,014
118
SIC Turn 7 & 8
www.germ.cjb.net
Sifu germ has already spoken :D I would say yrv are a good choice but the pricey way ;)
I'm a kuli only..no where near to be a sifu...just sharing facts to enlighthen other self claim personnel here...u are k3 sifu also ma...
then just try plonk a K20A into ur Kenari, get a set of HKS/Greedy/TopFuel turbo kit... boost low low 1.3bar... sure can not only monte bella, but Hawaii Five-O ler.....
cannot le boss...later bungkus AMUSE S2000 macam mana?
haih..chill la...dun diu here diu there...keep ur DIUs in the room...
1.5 3sze is not difficult to source... 3sze are increasing lately as more and more passo are scrapped..and we are SUGGESTING a more feasible approach..where there will be no/less complications later
i am running with emanage...ignition harness wasnt tuned as it was close to useless....getting 150 hp on wheels...with ron 95..boost 0.9bar...dynojet dyno machine @ toms sg besi...
3sze halfcut...it depends...sometimes can get around 5.5k too....but it can also go up till 7.5k...have to be wise...
you may obtain 3sze from:
* Daihatsu Terios
* Daihatsu Gran-Max
* Daihatsu Materia / Daihatsu Coo
* Toyota bB
* Toyota Passo Sette
* Toyota Avanza
* Toyota Rush
* Perodua Alza
where else before the 3sze was well known, people usually use the crank shaft and conrods of the 3s into the k3ve to increase volume...but i dunno whether there are any successful case...i mean havent seen for myself...but heard alot of rumours, logically it fits...both k3 and 3sze uses 72 MM piston...just the the stroke of the 3s is much longer..where the difference in STROKE is 12.1mm..which is quite alot..and that explains the CC increase...
It will be nice to mod your way up...but the expertise in K3ve in msia is scarse...so as in japan...unless you do it right which will take quite a while and more $...as the WISE man szeonn...the specs are easy to list and say...but calculations....are difficult to be right and precise..how many foreman in msia does the calculation?
remember...there is no replacement for DISPLACEMENT! :thefinger:
if u give me a 2nd choice..i would rather take 3S...but i did my transplant like 4-5 yrs back...mana ada dengar 3s?
agree with Turborized...changing to turbo engine is much more better than BOT...:burnout:
But this is still subjective la...personally i prefer NA raw power..keke...althought i am driving a turbo..
:bawling:
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
team99ers.2.forumer.com
lu kuli, i'm just a friday boy nia....:bawling:
here got no Amuse S2000, so dun worry... u got no chance to tapao 1...
mayb u can tapao R35 & see how la...
Accord80
96
4
3,008
Seattlewangsa
My opinion, if money is not an issue go for transplant. BOT is the only way for some ppl like me who don't want go to JPJ for endorse...plus my budget a bit tight la.
Furai
5
1,508
You're using stock clutch plate?
Accord80
96
4
3,008
Seattlewangsa
Used this nick long time dy, when I'm with Pro-hatch (Satria owner) b4...
Accord80
96
4
3,008
Seattlewangsa
true...potong steam if u boost and clutch slips..keke..
D-sport has a super single...that is oem from OS Giken one...RM bout 3.5k ...hahaha....
Me only use Trinity on my BOT Myvi. Cannot afford to buy those clutch. Trinity also not bad la....
TitanRev
You think I print money?
Mar 3, 2005
8,210
3,678
I put my vote on K3-VET....close eye, no doubt, no question ask....
Accord80
96
4
3,008
Seattlewangsa
I still prefer BOT. Don't know why, maybe coz I don't need to go Puspakom and JPJ for inspection kot....
Last Tuesday between 9-11pm (raining and AC area jam as hell) my car was broken into in front of Kedai Dobi, same row with Burger King (facing highway). Laptop and a Burberry messenger bag was stolen from the back seat. Laptop already had its battery removed and placed under the seat while the other was left on d back seat. My suspects:
1. Kedai Dobi fucker who was still working at that time when i just parked my car saw my friend trying to use his jacket to cover the Burberry bag.
2. Some...
