I am sorry...but i have to correct you...I dunno bout the exact HP for the 'R' version. Some say 140hp. but for sure, the pistons a little bit bigger than normal turbo YRV. plus the coil is different, has 'Igniter' box which the normal version don't have, two O² sensor, 220 meter, and no speed cut..
What makes you think the piston bore of a Turbo R is any bigger than...What do you mean by coil?K3 are running on direct ignition....
and all K3 has the DVVT coil...just bukak ur valve cover and see...
Speed cut? japanese governement has the regulations of restricting it...unless the halfcut is obtained out of jap...maybe Russia or singapore....
2 x o2 sensors? normal k3 has it too..even NA....
and think logically...what makes u think DAIHATSU will spend much more money on doing R&D for another base out of K3 but just calling it Turbo R...?
The main difference is the ECU...the fuel mapping in the Management is different...
at most daihatsu will play with compression...just like K3VE and K3VE2...they just raise the compression of the piston and change the ECU mapping...and there you have an engien with slightly higher output.....
---------- Post added at 03:15 PM ---------- 6 hour anti-bump limit - Previous post was at 03:11 PM ----------
Bro, between BOT or K3vet halfcut...i would go for halfcut..and maybe can kahwin with your k3 manual gearbox..Which one is a better choice for Myvi ?
Care to share your thoughts/experience?
Thank you
BOT is a fun process...but the tendency of going wrong is high...for a problem free solution...go get a K3vet halfcut..drive it stock...and its problem free..toyota/daihatsu engines are pretty reliable....when stock...
btw...there is another option since u are driving a myvi..get a 3sze....1.5 litre...same engine as alzas....
i would prefer CC...as there is not replacement for displacement.. cheers :rolleyes:
I am one happy owner here...with manual tranny boosting at 0.9 stock boost..now ppl selling full half cut for YRV is around rm8k++.. no need mod anything, still can drive syiok syiok tapao Vios ma...
