y does engine bearing worn out?
gti[GSR]
791
can anyone explain? y?
as i noe its due to :
1) oil pump (faulty)
2) insufficienet engine oil
wat other causes??? anyone noes?
softmuffin
384
sorry to ask,
what is this ? what will happen if it is faulty?
jinkl said:
u r right ,
but its meant to worn out ler , thts y must keep changing mar
jinkl
4,624
376
3,183
softmuffin : offer some muffin ler wei , hungry man hehehe
erm if bearings get eaten up :) then u can see ur engine getting eaten up :P
maybe conrod or crankshaft if in block ler
thts the reason they put the wear n tear in the engine. instead of the engine wearing , u let the bearings wear n change em
cypress8
1,440
Roger that Sir Jinkl!
gti[GSR]
791
but dis kinda bearings suppose to last few thousands of KMs man... like at least more den 100k KM rite?
if keep changing man everyone wud need to open up their engine all da time...
dere mus b a reason y dey wear n tear so much in sucha short time?
badguy
951
actually where is the location of the engine bearing??
i also noob lah!
how the engine been eaten up?
my car 140K already how to check the bearing eaten up or not?
phantomRX8
Insignificant Fool
331
5,018
ISS
well..there are a lot of possibilities but the most probably is because the overload on the bearings...things like detonation or engine knocking are the prime suspect for premature engine bearing worn out...bearing on the engine r made to withstand vertical load and some side load...simple things like letting go the clutch pedal harshly can shift the crankshaft sideways at a small margin laa...but can still damage the bearing in the long run...i had this friend who used mivec pistons inside a 1.8 mivec and engine knocked so badly when he open the engine,not only the bearing worn out but the con rod also went missing...only traces of metal particles in the oil sump..so try rectify the knocking problem..u might not hear the knocking but when there is crank harmonics..premature wearing might happen...just my opinion..hehe
phantomRX8
Insignificant Fool
331
5,018
ISS
i also noob lah!
bro..i think laa if u want to check whether the bearing is eaten up or not...maybe u can check the condition of the oil the next time u change the motor oil...try check for small metal particles within the oil...or do oil spectrometer test hehe..
gti[GSR]
791
due to engine knockin? hmm if engine knockin isnt dat due to insufficient fuelling?
i tot engine bearings worn are due to engien oil n not FUEL? /??? wat do u mean???
anfernee
246
Engine bearing worn out... could be frequent over-revving of the engine ? If stock ECU then can't over-rev but those that have the RPM cut removed.. or carburetor engines...
phantomRX8
Insignificant Fool
331
5,018
ISS
yup...well the basics of lubrication engineering is that the oil must provide lubricating
properties and oso shock absorbing properties..there are a lot more properties that the
engine oil must have but this is the important one laa hehe...then when there are crank
harmonics or vibrations which can come from any rotating or moving parts in the engine
the bearing will absorb the vibration and spread it over the surface of the bearing..oil on
the other hand provide sufficient lubrication and absorb the shock oso..so when there is
engine knocking or detonation due to the insufficient fueling..the harsh vibration from
piston crown will be transmitted to the crank via the con rod..if its too severe the bearing
will not be able to spread the kinetic energy of the vibration and the oil in-between the
bearing and the crankshaft journal would be displaced..then there would be metal-to-metal
contact..hehe...this is where the bearing would start to worn out until it is decimated..
insufficient oiling maybe the culprit but looking at the quality of today's automotive
engineering the oiling capacity of the oil pump shud not be a problem if only it is
in gud working condition...so if wanna go racing must upgrade maa..anyway this is one
of da probable cause laa..hehe..feel free to correct me if im wrong..we all learning
what..hehe..
zakie
131
u wanna noe y arr??
very easy one loorr...
bearing worn out.... hehehheheee...
lu rembat x ingat rosak...
dah rosak baru mau ingat rosak...
haiyaa..... lagi mau tanya.....
tak mau rosak simpan dlm garage....
gerenti x rosak....100%...
jgn marah aaaa.....
:dancing2:
u have 2 remember one thing arr....
once the rpm hit 7000 above....
sure it will effect u'r bearing loorrr....
and it depends on wat purpose u using ur
car 4...... :dancing2:
gti[GSR]
791
wellz dere mite b a reason frequency of it kept repeating...? mahf wen'sc ar he changed block like 3 times n dis tiem comin 2 fourth...
y? wellz from wat i read so far, its da insufficient fuelling....
Its new physique may turn some people off, not just because it's not particularly exciting to look at but the fact that there's little differentiating it from its predecessor. Forget about the mundane exterior for now. First, let me assure you, VW's latest Passat is definitely all-new inside and out and I am pleasantly surprised by its impressive refinement, and...
