Which is better for soundproofing ?
dripinrain
9
1,503
When travel fast, i had to up the volume to compensate for outside noise.
Looked around & got 2 options -
Rubberised spray
Workshop will spray the undercarriage & wheel well. Also said to be good to prevent corrosion & stones hitting below.
Damping/soundproofing strips
Workshop will lay on floor until firewall.
As the cost for both is nearly same, i wonder which option i should go for. Hope to get expert advice from bros before i commit my $.
pedas_385
71
iam using 1 cm aircond isulator.
verry cheap if you do it your self.
costing less than rm100 for internal including inside door
but if you done it at acessories shop, it will cost you about rm800
arturo
nooB
2,721
1,083
3,213
SateCelupLand
for those aircon insulator(some call superlon - brand name) can go to upholstery shop to buy bulk or get those with adhesive from ninja_iqa(precut). my roof has 16mm of this stuff n really cuts the heat n raindrop sounds off, but what i noticed is, this superlon cuts out higher freq sounds better than mid n lower freq sounds so sounds like tyre n wind n muffler sound still gets thru.
appleyard
773
Kota Kinabalu
superlon is for dampening, dynamat, sika, hustmat etc is for soundproof
duck_killer99
144
10
good and reputable, i would say the following, dynamat, sika, and stp(this is the most extreme 1, from rmXX-rmXXX/piece also got, dun forget is juz cash n carry, not include labor yet)
MyWifeCar
147
Puchong, Sgor
I would say go for both. Cut down both noise and you'll get rid of more noise~
Option 1 mainly for wind noise, option 2 is for road noise...It works differently.
To all you guys !! Please advice, how to reduce the harmful gases release from our petrol & diesel car engine.!!!
What are the parameters in order want to test on the harmful gases release from the exhaust emission?.
Where to find the testing center?.
May be you guys got better idea how to reduce the harmful gases from the vehicles petrol engine.!!!
let share some of your views..!
THX.
Actually , I am doing some findings.....on the exhaust emission (Petrol or Diesel...
