Hi Guy, as the subject, I'm selling the product as below. To Whom are interested, kindly PM me. For whom don't like to DIY, i can do the installation, kindly PM me for the quote.
1-Supression Pad :-
10pcs - RM 40.00
20pcs - RM 80.00
Spec:-
Specification:
Thickness ........................... 3mm (0.12 inches)
Size .................................... 9cm x 18cm (3.5 inch x 7.1 inch)
Color .................................. Black.
Weight ................................ 3 kg/M2 (0.61 lb/ft2)
62g (2.2 oz) per pad
Water absorption ................. <0.1% Wt.
Softening Point ................... 155°C.
Tear Strength ...................... 400N
Tensile Strength @ 23°C ..... 14KN/m
Adhesive Type ..................... Solvent Acrylic 90 gsm
Adhesive Temperature ......... 150°C max. resistance @ 15min
Adhesion to Steel ................ 1.1kg/25mm
Kindly refer to below for the photo
Product:-
Location to install:-
2-Flex Mat:-
1 roll (20cm x 122cm) - RM 45.00
Specification:
Thickness ........................... 2.1mm
Color .................................. Top – Heat reflective aluminum.
Underside - Black.
Chemical resistance ............ Resistant to oil, diluted
acids and alkalis.
Weight ................................ 3.1 kg/M2
Water absorption ................. <0.1% vol.
Melting Point ....................... 150°C.
Material is fire retardant.
Operational Temperature ..... -30°C to 80°C.
Storage Life ........................ Indefinite
Product:-
Location To Install:-
For others product, kindly refer to the link below
http://www.soundblok.g0ldeneye.com/
1-Supression Pad :-
10pcs - RM 40.00
20pcs - RM 80.00
Spec:-
Specification:
Product:-
2-Flex Mat:-
Specification:
Underside - Black.
acids and alkalis.
Product:-
