where can i get fuel cut switch ???
ntc2000
91
How much for it including the installed fees???
Can I get in Brother's ???
satriaSssEeeZzz
307
K.L/Cyberjaya
yea... i know which shop can do it... but i don't understand how the thing really works?... anyone here have a good explaination about how fuel cut work?...
the shop can do at serdang.. behind upm.. got 1 accesories shop... RM20
ntc2000
91
if that much different between simple and more function 1???
Which 1 better??? I just get my new car... want to install this kind of stuff to protect from thieves...
trex92
756
5,018
well, simple wan u can DIY urself. Buy a simple ON OFF switch and put it to the wire to the fuel pump or maybe ECU.
wfhan
4,339
96
selangor
how to go there?
how to go there if i come from UPM toll?
u got name/address of the shop?
wfhan
4,339
96
selangor
found some explaination in the DIY session
posted by member 'trex92'
"fuel cut switch works like the above mainpower switch. In our cars, we have a fuel pump, which functions are to pump the fuel from the fuel tank to the engine fuel lines so that fuel can reach the engine for combustion (thru fuel injector for EFI cars or carburetor for non EFI cars). The fuel pump needs also electricity to work, so a switch can added to the power wire for the fuel pump to disable the fuel pump. The feature of this fuel cut switch is that you would be able to crank the engine but the engine would not start as got no fuel supply. Most immobilisers uses the fuel cut as one of the forms of immobilising the car."
satriaSssEeeZzz
307
K.L/Cyberjaya
the name and add of the shop i forgot lah... the shop is around serdang tasik... theres only few car shop... sure you can find... the shop is corner lot...
wfhan
4,339
96
selangor
"the name and add of the shop i forgot lah... the shop is around serdang tasik... theres only few car shop... sure you can find... the shop is corner lot..."
isit somewhere very near to mcdonald ar?
ntc2000
91
Just install the fuel cut switch....(they known as arm switch).....
around rm35 ......
:marchmell :marchmell :marchmell
As the title mentioned!
My car colour is beginning to peel off,i dont know how that happen,but its just like a skin peeling off,it will start off with cracks then you can just peel it.
And my car currently have plenty of deep scratches.
So i thought of just respraying the whole car back.
Any suggestions based on your experience?
How much is it for just outside spray paint?
For an old celica what colour do u guy suggest?
