walbro 255lph fuel pump
e*terna
42
Hey guy....anybody had install this pump to 4g63 engine or others? is it worth it to use this pump with free mod? do you guy have any problem with this pump to set up the engine back?
SDF
missing her so much
Nov 19, 2003
2,354
275
KL, Malaysia
excellent choice for direct replacement..since it runs in-tank, less hassle compared to the external pumps.
i've used this personally before and it flows real well, but get it coupled with a fuel regulator for optimum usage.
jinkl-
552
Klang
stock erm i tink u can keep the stock one
if i increase then better just get the wallbro or sard
AlucarD
1,079
115
5,163
Yeah, get it direct wired as well :)
bnr34
403
6
mee to using on my 63. but dono wat different wow...
feel like same only.
DJmobile
946
different alot loh, upbooost then you can feel liao..
a bit of noise can be heard from the pump though...
buy tis mirage halfcut (4G92 Twin Cam Non-Mivec) few month ago... then i got a few question..
1. about my gearbox.. the rpm just like avanza...1st to 5th gear all same... fyi, i run about 85km/h on 5th gear.. the rpm show me 3000 already.. run on 110km/h rpm goes 4k... very high rpm means high fuel consumption... last time i used 4g15p, 90++km/h on 5th gear baru 3k... help me? do i need to find another gearbox? i prefer more to fuel-saving:proud:
2. can i change my stock radiator...
