yung
this walbro fuel pumps have latter to prove is original,MADE IN USA
WARRANTY:3mont
this walbro fuel pumps 500hp also stable air fuel ratio
walbro high pressure electric fuel pumps are available in flow ratings of 255 liters of fuel per hour.these particular pumps flow significantly more fuel at higher pressure .for example ,at 80psi the standard 255 lph pump will flow around 132 L per hour .at the same 80psi the equivalent high pressure fuel pump will flow 210 L
CALL 014-6411291 to order
WARRANTY:3mont
