Shell Helix
There are 3 typical oil types we’re most familiar with. Starting with mineral, semi synthetic and fully synthetic oil types. In this order, its price and performance increases exponentially.<b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b>
Mineral Oil
As with most engine oils, Mineral Oils are derived from the crude oil extracted from under the ocean through fossil oils. The crude oil is then distilled and further processed to acceptable levels for automotive use and should contain some level of additives. Mineral Oils have been the baseline product used by car manufacturers as it is the most cost effective while maintaining the minimum accepted quality for consumers.
Semi Synthetic Oils
Generally blended with no more than 30% of synthetic content, semi-synthetic oil further increases lubrication performance with improved corrosion deterrent ability, sealing, and can withstand higher operational temperatures. Synthetically blended oils also has better friction reducing abilities compared to pure mineral oils
Fully Synthetic Oils
These are the best engine oils that is engineered to outperform mineral based oils with even greater low and high temperature viscosity. It is also blended with advanced chemicals for shear stability, resistance to oxidation, thermal breakdown and greater prevention from oil sludge. Fully synthetic oils also lasts longer for extended oil service intervals, resulting in less oil wastage. With the merits of a fully synthetic oil, comes with better protection for a longer engine life.
Car owners who demand the best typically find it more worthwhile to purchase synthetic oils for its benefits in greater protection and longer service life clearly outweighs its higher purchase costs.
For example, the Shell Helix Ultra 5W-40 is five times as effective at removing sludge than mineral oil with friction modifiers that helps the engine to unlock additional horsepower while reducing wear to a minimum.
The Shell Helix Ultra is developed with Ferrari and is the preferred choice for the Italian high performance automobile manufacturer.
More about Shell Helix Ultra Engine Oil
