Spark plug fire spark at outside of the engine??????
cheng_Y
Aug 5, 2011
17
503
Car : WIra SE 1.5 EFI Siemen VDO
Issue :
- The spark plug spark/fire spark at outside of the engine block.
- Intermitend not every time.
Effect :
- Engine not running smooth when idling.
- Some time engine will mati.
Action taken :
- I change plug cable (Aro speed 10.4mm)
- Change coil - Bosch German made.
- Change spark plug (Normal type RM25, gap setting 0.7mm)
- Change Map sensor.
- Change crank sensor.
- Top overhaul.
Finally :
PROBLEM UNSOLVE!!!!
What could be wrong?????? PLEASE HELP????
ken yeang
6,618
1,327
I used to have the problem, until I changed to a set of new spark plug cables. The old cables insulation developed cracks, and spark "flew".
Perhaps you should check electrical grounding cable/wiring in the engine compartment.
15,390
I just noticed you changed to the Aro (speed I assume) plug cable.. why la? The best 'cheap' one is still stock, ie- bougicord. Try using back your old cables or try swapping with a friend and see if it solves the problem.
A Post Every 5 Mins
ok guys..my brother car got big problem. his car temperature going high when switch on aircond and the coolant kick back to reserve tank, esp during heavy traffic jam or long hour journey. but weird is his car temp will be ok when switch off aircond during the same condition. when check inside the radiator no oil or syptom of burning gasket...
dunno what is the prob still cant find it...izzit bcoz of termostat, stuck radiator etc..plz help :)
