Car : WIra SE 1.5 EFI Siemen VDO
Issue :
- The spark plug spark/fire spark at outside of the engine block.
- Intermitend not every time.
Effect :
- Engine not running smooth when idling.
- Some time engine will mati.
Action taken :
- I change plug cable (Aro speed 10.4mm)
- Change coil - Bosch German made.
- Change spark plug (Normal type RM25, gap setting 0.7mm)
- Change Map sensor.
- Change crank sensor.
- Top overhaul.
Finally :
PROBLEM UNSOLVE!!!!
What could be wrong?????? PLEASE HELP????
Issue :
Effect :
Action taken :
- Top overhaul.
Finally :
PROBLEM UNSOLVE!!!!
