Mr. KHGuan, can u explain in more details.............thanks thanksuse superlon on ur wheel arc... 10mm will do...
u need to jack up ur car then remove de plactic arc cover.. clean it with damp cloth then stick superlon on it... (de superlon facing inside ur fender....)
I suggest you to change to more quite tires first.Originally posted by R3l3orN@Dec 26 2004, 00:56
Currently, i m driving a Satria........Front 2 goodyear's tyres.........n rear 2 sime's tyres.......thanks :D
That's what I heard from the tyre shop also. You want quiet, got to sacrifice performance (grip). Another tyre feature to look for is those with fine gaps which generate less road noise.Originally posted by khguan@Jan 7 2005, 15:10
those with many straight lines..
but of course de performance is not as good as those tyres meant for cornering n wet driving...
