something need for help
rayracer
7,133
11
CHERAS,TMN CONNAUGHT
NIL
my car satria will convert to 1.6 engine (SOHC),play play only,but wat kind of piping
exhaust system fit my ride? i only need is power in more pick up,middle power,fast to
soon in top speed,but make sure sound is quiet do not like blass!!
hope can help!:smile:
and others thing is where can find a rear brake disc system to my satria in low price??
gsrTurbo9166
958
ok bro
u can use 1.8"-2.0" exhaust system to install to ur car
if u don wan loud noise then use s-type or put 2 center bullet to ur n1 type racing muffler
hope this can help
gsrTurbo9166
958
which 1 u mean???
if s-type import direct from japan then will cost u around few hundred la
if u put 2 center bullets that will cost u around 300
rayracer
7,133
11
NIL
the first question no somebody know??
izzit 4g92 sohc can convert to dohc head?? or put mivec head?
wat kind of exhaust system can get the power on pick up to mid rev and fast to top end???
johnnygsr
372
5
4G92 can put Dohc but need to do some wiring & oso change the ECU.
rayracer
7,133
11
NIL
Fluffy said:
change ur flywheel to a lighter one might help..
walau!! friend! tat thing i know,but my problem now is i hv a engine
is sohc head 4g92,need to do mivec head or dohc?
and the piping exhaust is how big is good?:smile:
johnnygsr
372
5
rayracer said:
then now running 4G93 sohc wiring,4G93 MMC ECU
is tat means need to put dohc wiring and dohc ECU??
Check sure u using DOHC MMC ECU for 4G93? in this case just need to do tuning only. of coz wif wiring.
xin
626
YES u can convert ur 4G92 Sohc to Dohc by swapping into 4G92nonMivec head or Gti head or 4g91 head
wiring and ecu NO NEED to change but u need a 4G91 carb distributor as 4G92 Sohc distributor diameter does not fit the head.
if wan swap MIVEC head also can..but MUST change mivec Ecu n wiring.expensive
As for straight flow it gives better mid to high end...
for same curve as ur n/a 1.6 but change to 2" piping+mid bullet + s-flow type muffler as this will provide better low end and mid torque(better pickup)
stainless steel more better(coz i using setup above on my 1.6 last time i use straight flow hks very bassy when pickup n power onli comes on mid-high end)
the bigger ur mid bullet the more quiet u be...
xin
626
4g92p sohc...lol
plans:4g93head dohc on progress
u from connaught izzit?last time i live in Suntex hahathats why i knoe coz done research already lol..cheers
p/s:all i mention is true, some blady mechanics will talk rubbish sayying need change ecu/wiring la, ditributor need skim la...u see these mechanics then u can walk away.Dun let them touch ur engine...my experience cheers
juz follow my info will be nice lol..
rayracer
7,133
11
NIL
xin said:
4g92p sohc...lol
NOW WHERE U LIVE?
how much is put a dohc head? coz i need to change mivec head:shocked:
rayracer
7,133
11
NIL
if used mivec system already,the throttle body used to big izzit got problem??
how big is o.k? 60mm?? if original from 4g92 throttle to port n polish it izzit o.k?
how the fuel cossumption
A Post Every 5 Mins
got my license in time for this event.
it's held as part of the run-up to the big, ops i mean HUGE event call the Asian Motorsports Festival (AMF) organised by AMF Group.. (boss is S'porean)
and it's HUGE
qualifying rounds for DRAG, AutoKhana and Autocross is held in Thailand, S'pore, Indonesia, Taiwan AND of course, Malaysia.
ALL finalists (top 30% in class) will be then qualified for the finals which will be held in Sepang.
an estimated crowd of 100,000 will be expected!! holy coW...
