Dan KC
Check the master pump.the master pump cant hold the pressure that why when u brake the pedal will slowly drop to the floor
Not to say the pedal slowly drop to the floor. Is just that when floor the pedal the braking power like not much feel on it.Check the master pump.the master pump cant hold the pressure that why when u brake the pedal will slowly drop to the floor
Yes bro, I did downshift to slow down the car. As now the brake power is more worst really hope to get improve it!I own a Saga BLM as well. The brake is not so strong like other cars so you will have to brake earlier to stop properly. Also hard braking is useless so try downshifting to help you stop
steel braided brake hose help my olskool car to haf a better braking feel.Steel braided hose? Does it really help?
Need week will need to drive to genting. So might need solve it faster too.
Help help help~~~
Brake flushing does help?steel braided brake hose help my olskool car to haf a better braking feel.
but i tink the price now is a bit too steep..
i tink u shud really consider do brake flushing 1st.
But after the 3rd service I have sent the car service outside due to company issue. Do u think still can get free?
---------- Post added at 09:33 PM ---------- 6 hour anti-bump limit - Previous post was at 09:32 PM ----------
How long does the pad n disc need bedding in?
Bit then next week I gonna use tis car to genting. Urge on tis matter :(go to the sc when u r due for servicing, usually they allow warranty claim with one condition...u do 1 major service there...then u r back on track...give them strong reasons for not servicing yr car at proton....
u'll be amaze wat a simple service maintenance can do.Brake flushing does help?
How to justify the master pump is giving problem?My Myvi had a rather similar problem, when initial press of brake there is slight bite but it is not continuously biting. When the brake pedal almost reach floor will have additional bite usually causing the car to jump over a bump as I was unable to accurately control the braking speed. good thing my foreman is experienced. Found out it was due to master pump.
195/50/R15slightly out of topic, what tire are you currently using? size?
