Gearbox Saga BLM
beartokun
Jun 3, 2011
6
Hi all,
since 2008 im using Proton Saga BLM 1.6 taxi spec but not a taxi........ now it time me to upgrade my car for more performance.
here are the thing that i already install it into my car:-
1) 4-2-1 Extractor
2) Highcam 262
3) Adjustable Campulley
4) EMS-1 Piggyback
now i thinking about using LSD into my car
i need suggestion from u guys should i put aftermarket LSD add-on or change the gearbox to MIVEC CK?
are MIVEC CK gearbox can put into my Saga BLM if can is there any other modification needed to install it?
so guys please help me...:confused::confused::confused::confused:
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Do anything except don't ever transform your BLM into this: :biggrin:
beartokun
6
why i need to change it because
1) cost: aftermarket LSD is 900++ plus workmanship is around 200++ & if im buying CK gearbox is around 1500++ and gear ratio also i can select which one i need........but right now i'm confusing if i choose the first step maybe i will added additional cost .......but if i choose the second one also added additional cost of change the gear lever and much more.....so i need opinion from your guys.......the main reason is i want to join "SNF"........
Hi guys, i was looking at my car just now and i noticed there's a crack at the front panel of the body frame (the part near those radiators / behind the bumper). There's a crack and i'm worried my whole front part will fall apart.
Could you guys recommend what i should do and any workshop is good in repairing or fixing this.
