Rear disc brakes for Iswara
Kelis
162
Hi to all sifus out here. Hope u guys can help me out with this. Which set of rear disc brakes are most suitable for an Iswara? VR4's? Any other suggestions?How about the price? Thanks in advance. :tee:
johnnygsr
372
5
All my iswara fren use Mitsubishi Mirage rear disc. It fit just nice. If not mistaken price is around RM500-600.
darahhitam
2,483
5
www.cardomain.com
Go here:
http://www.zerotohundred.com/newforums/showthread.php?t=3022
Long discussion on Saga/Iswara Rear Disk Brake Solutions.
Mirage is still the ONLY plug n play rear disk/caliper set for Saga/Iswara.
The rest require mods.
Typical market price -
Mirage - RM600-RM800
VR4 - RM350 - RM450
Supertouring RM400 - RM500
zakie
131
:albertein
aLop geng....
u own an iswara standard or turbo?? if turbo i suggest the vR4 rear brakes.... but for standard better use the drums, better maa....
the right condition for braking sYstems is the front braking must be better than rear.... u know Y or not?? becoz aaa, if rear braking is much gripping than front aaa..... verY dangerous coz it wiLL make ur cars spin during the emergencY brake.... the rear brakes is onLy to support the front braking in order to stop ur moving vehicLe.
but nowadaYs aarrr ppL onLy wanna Looks prettY onLy their car....
so theY ignore the reaL usage of the rear brakes....... :secruity:
but its up 2 u Laaaa..... its ur moneY....... :rock:
:dancing2: :dancing2: :dancing2:
SkYwAlKeR
10,139
300
ePoh ~ malacca
yah, if rear brakes more powerful, they will lock ur rear brakes (rear brakes tend to lock easily)... thus, this will lead u to a spin if not careful...
better get a front vr4 single/twinpot brakes, then only upgrade rear to disc brakes...
anyway, if ur car stock, jz get better brake pads can adi lo..
darahhitam
2,483
5
www.cardomain.com
And if you need just adequate braking power, much better than stock, then there is NO NEED to change anything. Just the Brake Master/Servo Pump would suffice.
Kelis
162
Agree with bro. Skywalker, just change to better brake pads will do, or u could go with bro. darahhitam's opinion, that is to change your brake servo to a bigger/better one.
Just my 2 cents... :)
Doink
3,492
House
put rear disc better...better heat dissipation...my car...using vr4 disc front and rear drum...brake very unbalanced...biased towards front...so its like rear without brake...
SkYwAlKeR
10,139
300
ePoh ~ malacca
means if upgrade, must upgrade both front and rear??
Doink
3,492
House
standard iswara has disc for front and drum for rear...while using this standard settings,most of you guys i am sure will notice that the rear drum tends to lock easily...I nearly meet with accidents a few times...because the rear locks and the tire skids...which means no traction thus there is no brake...nearly met with accident 3 times...the front disc doesnt have much grip...
so the first step i did was to upgrade the master servo...this provided better braking power...means...i get better grip compared to earlier...but still it doesnt solve the rear drum locking up and losing traction...and the pedal feel is very hard due to the powerful vacuum of the bigger servo...
and then follows the next solution is to upgrade the front disc to a bigger brake pump...solution is to use VR4 single pot...which is very sufficient...so i get better grip at the brake in front and softer feel on the brake pedal...
there is one part...i need to change...the brake line divider on the firewall in the car...where the main brake fuel goes in from the master servo and 4 out to each brake pump at each wheel...changed to wira...which provided better 50:50 division...
now the last problem is sometimes the rear still can lock...intermiten...but mostly front will lock 1st when braking hard while driving fast...further plan to upgrade rear...then update you guys...
Kelis
162
Ah... Sifu Doink, if u don't mind my asking, what type of brake master servo do u recommend for an Iswara? The one from a Pajero? :shocked: Any comments?
Thanks...
Doink
3,492
House
pajero is very sufficient...because its vacumm power is more than enouigh for a small and light car like iswara...try it and u will understand believe me...
darahhitam
2,483
5
www.cardomain.com
I've used Supertouring's (E12A) & Galant's E33A. Both are sufficient for putting sub 1-tonne car to stop.
kher
1,533
Klang, Selangor
If u're using iswara standard the pajero's servo is way too powerful n sufficient for u coz tat's wat ppl used for turboed cars actually.
For ue rear disc brake try to get the mirage 1. It fits nicely w/out much mods to iswara. But it's quite rare if not mistaken.
hey i kinda (accidentally) put in too much motor oil into the engine today <_< would that be a bad thing? it's about 1cm past the upper level mark on the dipstick...
