Radiator Fan Problem
natureguy
11
my car radiator fan wouldn't stop after i turn off the car... any1 can tel me where the problem.... stock gti........ is tis the heat sensor spoil? of the fan spoil? i din modify it at all.........
Viperize
31
do u mean it NEVER stop although u TOTALLY switch off the ignition ?
if u totally switch off then no more battery power mah....
natureguy
11
Really Need Helllpppp!!!! Serious Problem!!!!!
i turned off d car n have took out d key ady. then, suddenly d radiator fan turned on itself and it would not stop.when i took out d relay of d radiator fan from d fuse box,d fan still continue to run by itself. the fan keep on running till my car battery run out. i have to start d engine,turn on d air-con;then turn off d air-con and off d engine car,then only d radiator fan would stop. HELLLPPPPP!!!!!!!! PLEASE!!!!!! NEED HELP FROM PRO_WIREMEN!!! anyone faced this problem before??
BlueG
433
For your case, I think the radiator fan is now bypass the ignition swicth to get the power supply. Maybe you can check the wiring or the fan relay.
CYLINDER HEAD PORTING AND POLISHING
Maximum engine power depends very much on the rate at which air can flow into the cylinders. Airflow efficiency is dependent on the design of the air intake system and the cylinder head. One of the factors that affect the peak power output of an engine is maximum port flow at the cylinder head.
However, always remember that peak engine power (max. hp @ RPM) is NOT the most important consideration for a road car engine. More critical is the average...
