Power Windows - WAJA
khai30
17
anybody expertisezzz,
got problem.... power windows driver seat...stuck!!! jam at the midle...huh....how much its cost....????.....some said its windows gear can not operate oredi.....
:sad_smile: :sad_smile: any rekomen workshop arrr ( KL area )
SurboNight
75
Standard maa.Legendary power window problem,Well you can try at Greenwood,one row with tyre shop there have 3 workshops,with different expertise.If stuck like you said it is possible of two thing,your power window gear has jammed or window bracket (White thingy one holding the glass,when open the door trim you can see)break.Cost around RM 150 above.:regular_smile:
khai30
17
greenwood
bro,
greenwood which area ??? at bus station :regular_smile: ???......may be i drop by 2day....susahlah nak smoking...tension...ahhhhh
[s]UpErNoVa
313
haha.. legendary PROTON cars problem.. guess u hafta change de bracket of de power window bro.. :Not_Impressed:
halo! izzit a good cooling system will be good for engine performance?
last time my car(satria 1.3 carb) repair the radiator and head gasket(the gasket blow),and then i try to rev up,wooo!!
i feel the car going too smooth the power! i c the water temp is going down,(normally in middle)
i planning to upgrade the cooling
-radiator cap 1.3kgm (normal 0.9kgm)
-high pressure radiator hose
-radiator cooling plate (fit infront of grill above)
-radiator bubble catch tank
izzit o.k? or still...
