PLS help ..my car is hunger for petrol...
ccc8910
80
3,008
i m driving a wira a/b 1.5 auto year 2001...
wat i found out is the car really eat alot of petrol (for me)... last time when the petrol price still (rm1.62) ... i can only manage to go 250KM for RM50
worse...when nowdays (RM1.92) RM50 can onli go for 200KM....
izizt something wrong with the car?? i normally maintain the rpm below 3..city driving only..pls help...
Doink
3,492
House
change to 1.6 injection...saves more fuel on the long run...because u no need to press much on the accelerator...
gohkokeng
2,443
u can go try pump petrol RM10 for each brand of petrol
SHELL RM10
ESSO RM10
MOBIL RM10
CALTEX RM10
BP RM10
PROJET RM10
the combinations of all formula will give u the feeling
ccc8910
80
3,008
SHELL RM10
ESSO RM10
MOBIL RM10
CALTEX RM10
BP RM10
PROJET RM10
icic...but my frenz told me that he is going for 1 petrol (shell) onli...from the 1st day until now...he said mi the petrol will affect the engine?? is that true??
ccc8910
80
3,008
SkYwAlKeR said:
try change new spark plugs and check ignition timing (i guess u got this answer in 4gtuner forum adi)....
and reset ur ecu...
yeap..i got advice from that forum also...thx man
gohkokeng
2,443
lol i was just kidding la.......me also use shell cause got BL link card and believe the SHELL so called claim their fuel "LEBIH KILOMETER"
ABV9750
322
auto? haiya normal la...if you drive slow-slow, actually you need extra torque to move when you changing lane or accelerate.if you use manual, OK la like taxi driver did.
my suggestion, change your drive habits. this is how i try to improve day to day..
from traffic light for long straight,press your acceleration harder so that your car cruise...then you don't need extra torque. in traffic, just relaxed..minimize acceleration. in hiway, try to maintain 90-100km/h..don't play with the pedal.
if you ganna travel very short distance, just relax..don't speed up.
OFF your engine when you need to wait more than a minutes.
change your D to N when you're at traffic light or not move.
ensure you use light oil at least 15W50 and change your auto oil every 20k km.
reduce your car load..change to std rims. or 14" just nice.
your tyre pressure always correct at 200/210kpa
when brought to the mechanic, please do normal service, change spark plug, tune BTDC at 6 to 8 deg. reduce CO% at optimize level.
change new original air filter.
if you're using after market exhaust, change to std unless you're using good proven exhaust system like hotbits etc.
if you wanna try the fuel saver products,you can try to install at 3 main element
(fuel, air and spark)..
e.g: increase your spark by changing to NGK racing spark cable and iridium plug.
use hi flow air filter like K@N or apexi filter for open pod.
good luck.
aku_sangap
1,172
15
Tengah Laut
or better still, change to manual tranny...;). or change engine...4g91 or 4g92 (mivec if u want more power)...;)..
ccc8910
80
3,008
good luck.
wow thx bro for all the details...i thing i m doubt is..i heard my mention mention that dont always change the gear from D to N ...coz is not good for the gearbox...is that true?? thx in advance..:regular_smile:
ccc8910
80
3,008
war..kenot ler..still student...no $$$ lehh :Not_Impressed:
acbc
4,615
KD
With new price, RM 50 for 200km is normal la.
BECAUSE u get less petrol for the same price!
Calculation:
RM 50 = 250km (@ 1.62) or RM 0.20 per km
RM 50 = 200km (@ 1.92) or RM 0.25 per km
LilKeV84
193
Subang Jaya
15W50 oil?
thats too high viscosity liao
wanna save petrol u should use 30 if possible
never use mineral...use semi or if best full synthetic
i think full synthetic got no 30...so use 40
Does anyone ever heard or experienced it?
Have taken the car to COE (they kept for few days), other proton SCs, auth a/c sc etc. None seems to able to rectify the cause.
Symptom: engine stalled during heavy rains or after sending for car body wash whenever the compressor turned on. But if only fan on, engine is fine.
One auth a/c sc has ruled out compressor locked nor problem with a/c system after doing thorough checking including disconnect the compressor connector. Engine still stalled...
