Please Help: Chamber Kits
chriiz18
Does anyone know where to custom make a adjustable chamber kits and how much?
I'm using 20" wheels and my tires only eating inside pretty bad and middle still let about 80% .
Please help.
Thanks!!!
CAMBER. Not CHAMBER. Chamber = some big room in some castle...lol
What car are you driving?
Re: Please Help: Camber Kits
lol...sorry for the wrong spelling.
Merz w210. i hardly drive my car but recently notice the left side
of the tires are badly worn. A friend told me i need a camber kit to solve the problem.
I only notice they dont sell adj camber kits for merz.
So if anyone knows where i can make one?
tire size im using is 245/30/20
suspension setup is H&R / blistein sports yellow.
woah...that's a very B I G tyre size for the merc...it's very normal to have such irregularities.
Firstly, if you haven't already done so, get your car aligned properly to equalize the camber for front and rear tyres. Remember the camber numbers.
If you've already done that, may I ask how far have you driven since you changed the tyres to have it worn out to such an extent?
I suggest reading up on alignment issues:
http://www.familycar.com/Alignment.htm
So assuming you know EXACTLY the above, examine...which side of the front left tyre is worn out? inside? outside? Examine the other tyres for wear patterns..are they worn out the same way? If not how? Document exactly the wear location for each tyre, and the extent of wear of course.
If it appears to be all over the inside and outside of the tyre then you might have an alignment problem on one side and not the camber problem. Too much positive camber means your outside will be worn out, and the general steering feeling is not stable..too negative a camber means the inside will be worn out, but shiok to drive..heh heh..your steering will also feel heavier and not return to the centre as easily as before.
Should you alignment be EQUAL, then you're probably going to have to examine your driving habits - are you making more aggressive right turns than left turns? Like that sure ur left front tyre wear out faster, especially that you are on big rims..even faster..haha
Anyway, online ALOT of places selling..here are the rear camber arms for your car (you need to scroll down)
http://buyit.mercedestuningmag.com/Suspension-and-Steering/Caster-Camber-Kits
and the front:
http://www.iapdirect.com/product.php?productid=41965
with your oversized rims/tyre combos, you should aim to have as FLAT a contact patch as possible when the car is turning and going straight. Obviously, given the caster angle of a merc, this may not be possible..so your alignment mechanic is going to have to be experienced enough to know how to compensate...DO NOT listen to those who anyhow tell you to "buka camber" or "boleh boleh boleh!" to any suggestions...IF there isn't anyone else here to chip in with the agreeable numbers, I suggest running 0 to 0.5 camber for a start and see how the tyre wear rate is like..
have fun :D
