Oil Cooler
erictan30
167
All sifus!
Is n/a car can put an oil cooler?have any different after putting it?wat's is the benefit putting it?
dean75
149
Port Dickson
One thing for sure, no hot engine problem, your engine oil will not be too thin/gas up ( to that extent ). I believe adding an oil cooler to the engine system is not necessary to N/A referring to normal driving, but a good choice for those who're 'kaki lari' ..... all sifu, please comment if I am wrong....
erictan30
167
but i think if we alwiz rev high should better install wan kua.so that engine will not so hot
TitanRev
You think I print money?
Mar 3, 2005
8,210
3,678
Its good to install an oil cooler no matter its NA or TC or SC. Keeping the lub oil within its working limits is good. Will help you avoid overheating problem and damage engine parts.
gavan
1,408
Shah Alam
erm, anyone knows how much does an oil cooler cost and where do we find it? looks like its kinda rare this item....
acbc
4,615
KD
Oil cooler is cheap... ranging from RM 50 to 200 depending on size / brand.
What is difficult to find is the adaptor - u need to screw this to the oil filter port n relocate 2 hoses to oil cooler. The oil filter then screw to the adaptor. Some adaptor have mounts for oil pressure / oil temp sensor - these are expensive.
nukleus
26
the adaptor it self cost rm250 - rm350
gavan
1,408
Shah Alam
woa, i see...so is there any way to get a solid confirmed price? sounds bloody interesting this thing is... ;) can be transferred from engine to engine right?
BabyGodzillaGTi-R
400
7
5,018
Better if u can find a kit for your car complete with the oil filter adaptor and all the hoses and joints.
If u just have an oil cooler, dont stinge on hoses and joints. Get the best quality hoses and joints and preferrably "10 or "12 size. Also take into consideration of the length of the hoses. The longer the least ideal. Coz u dont want to fit it wrongly and suffer low oil pressure and that is ultra bad for the engine. U might even consider adjusting the oil pressure relief valve to up the pressure after the oil cooler is installed. But dont over do it as it can over stress the oil pump gears.
Just my 2 cents.
erictan30
167
there are 2 size of adapters.for bigger type of oil filter and smaller size of oil filter.i just bought 1 oil cooler from chop shop at Rm100 and adapter rm200
dean75
149
Port Dickson
if i may ask, from which car the oil cooler attach to previously and what's your ride ?...Will you let us know what's the result after you install it to your ride?.....thanks man:_:
TitanRev
Mar 3, 2005
8,210
3,678
Bro, after fitting the oil cooler. Do give us a result on the installation, want to see how good it perform.
khoyos
2,633
156
5,163
Shah Alam
3 years ago i installed oil cooler to my 4g15 engine.
seriously didnt feel any improvement. my 4g15 was a high rev engine, exceeding 8000rpm.
i guess u could monitor the difference if u have oil pressure n oil temperature gauge. but seriously without those meters installed, its hard to feel or know any improvement...
KE2020
262
I have it installed in my 4AGE. U can't feel anything for sure, cos it only cool down your engine oil thus preventing your engine oil to overheat when high revving like during drifting or tracking.
So the purpose of installing it is just to protect your engine, it won't improve any horsepower.
khoyos
2,633
156
5,163
Shah Alam
yeah bro, u cant really feel any improvement. if u want to know any improvement, must install meters.
dean75
149
Port Dickson
I dont mind installing one and spend money because it's good for your engine ( to keep the temp at it's best )....too cold not so good and too hot is bad for your engine.
khoyos
2,633
156
5,163
Shah Alam
i got a set of vr4 engine oil cooler. here's the pic. dun have the adapter. anyone interested? rm80 only hehe
gavan
1,408
Shah Alam
fuyoo, make this into sale thread pulak, looks tempting butthen budget doesnt allow any spending on the car yet.... :(
khoyos
2,633
156
5,163
Shah Alam
:regular_smile:if there is any complaint, i will immediately delete the posting. dun want any unwanted trouble with ZTH authorities...
A Post Every 5 Mins
hi guys, wanna to know about what is weber carb and what is 4 throttle?
i tot both things is the same just the name tak sama oli, but my fren told me that i am wrong. is not same.
so, nid to ask expert here about this. just wan to make it clear about this two things. pls give me more info about this. thanks 1st to u all.
