Offset issue...
arrowhead
4,621
152
5,163
Damansara/PJ
ok i have this minor problem which to me, is annoying =(
i changed my rims and tires recently. to fatter/thicker tires (50 to 55 series) and silly of me, to not take note of my new rims offset. so apparently the offset is lower (wheel jut out more) and i only notice this when i take corners at high speed. my tires rubs against the fender.
what i did was, i adjusted the rear camber -ve, so it wouldnt rub on my fender. that's settled.
now my front is also touching, when i do kamekazi u-turns without brakes. i dont have an adjustable camber kit on my front.
i have some solutions in mind, but would like to see opinions from u experience guys as well.
1 of my solution: get harder springs, 8kg Front, 6kg Rear. <-- would this help?
my car is quite low, 1 finger gap front and rear, dont really wanna put it higher as it will be ugly =(
help pls sifu's ...
thanks.
zenom
75
but why u change ur tires to 55 in the first place ?
i thot thin tires are good if u would like to 'bantai' some corners
huhu
btw, ur car might be bouncy if u change to harder springs .
dont u think so ?
JINEIL2EN
15,317
525
Island Of Pearl
team99ers.2.forumer.com
my tires out bout 3mm from arch, & most of my fren's rides oso tires bout a few mm outside... but no 1 facing this prob, coz when u decided to get those offset & lowered, u must know wat will causing the prob, so... prevent it b4 install then regret..
fstr
7,934
954
Sahara Desert
u must know ur rim offset 1st b4 swapping maa..
offset numbers more means ur rim will be more inside.
offset numbers less means ur rim will be outside more.
arrowhead
4,621
152
5,163
Damansara/PJ
That's why la. I totally forgotten abt the offset issue. Not regret but looking for solutions. Why 55?cuz I got an offer I couldn't refuse. And yes, harder spring would mean sacrificing comfort and I know that for a fact. On top of it, I feel my springs are too soft also if I decide to test power in sepang one fine day. Haha.
Jin: confirm it's cuz of my soft springs.
So just wanna reassurance that stiffer springs would help me in my issue
arrowhead
4,621
152
5,163
Damansara/PJ
Lets say if I get back 50 series, I will lower my abs again to have the height of 1 finger gap from tire to fender-wouldn't the same scenario apply?
So I believe it's more of the offset rather than the tires...
Wanggot
3,906
62
Jay Bee
Civic owners EG/EK usually go for offset 41-45 if 7inch width.... And offset 37-45 if 6.5width... Most sifus recomend dat combination....
JINEIL2EN
15,317
525
Island Of Pearl
which sifu reco that..???:adore:
Wanggot
3,906
62
Jay Bee
Try go to hondacivics.nz or sumthing sounded like dat..... or civic4fanatic.com... really cannot remember which website...
BTW I tot u one of the most active forumers in Honda ZTH... Mayb U got sumthing to share abt this offset issue perhaps?
JINEIL2EN
15,317
525
Island Of Pearl
hahaha... sorry bro, i'm active in anywhere in ZTH... not in Honda section la...
btw, i'm just tok kok only....:rofl::rofl::rofl:
yo bro, can pass some civic forum to me that u used to b..??? just wanna see wats the difren with local forum. thanks...:adore:
Wanggot
3,906
62
Jay Bee
Very easy bro... Just type Honda @ civics @ vtec then dun forget to put country codes at the end of web adress. for instance www.honda.com.sg (sg for Singapore), (uk for United Kingdom), (nz for New Zealand) and so on.... Very interesting though getting know the scenario at other region...
JINEIL2EN
15,317
525
Island Of Pearl
thanks bro....
JINEIL2EN
15,317
525
Island Of Pearl
jin - i thought u are a walking library adi? haha jk... =)
mayb Lying more suitable... coz everytime i log in, most of the time is lying on the bed 1...
btw, must give face ma... cannot always right 1, so, if ppl said got SIFU, then must learn from SIFU... must give face to SIFU & i dun mind to learn more from the others...:adore::adore::adore:
arrowhead
4,621
152
5,163
Damansara/PJ
haha true true well said sifu well said... :adore:
zac
1,347
231
Johor Bahru
if is just kena a little bit then you can try flatten inner part of your fender, that might help... just fyi, i changed my 55 to 50 also kena a bit, just very little help by changing tyre... Also, sport tyre tend to have wider thread and will kena but comfort tyre might escape from that, i tried 55 ad07 and 55 goodyear nct5 earlier...
JINEIL2EN
15,317
525
Island Of Pearl
i'm not sifu... u la sifu...:adore::adore::adore:
not recommended to flatten the inner parts of ur front fender or the rear wheel arch...
Similar threads   Forum
Similar Threads
Hello to all sifus out there...
Newbie here...
I need some help regarding how to indentify & located the ECU wires arrangement...
I drive a Satria with 4G13P & SVDO ECU..i know where is the location of ECU in my car...
The problem is, i don't know which wire that carry signal for O2, RPM & KM/H...
For your information, i want to install HKS Type-1 TT & my DIY AFR meter by myself...
Is it true that most wires in ECU has in & out?
A friend of mine said that if we want to tap a...
