Need proton satria modifation advise
cowcow
sabah
I had a proton satria chassis with 1.6...
now already 4g93 gsr turbo almost for a month...
but the engine light was on until nowaday that wondering what happen...
and also need to ask which adjustable more suitable for it...
what is spring rate 6k front 4k rear means?
TQ
You need to plug in a diagnostic to retrieve the fault code
I drove satria, had used adjustable with spring rate 8k front and 6 k rear. Too hard to drive and very uncomfortable even on malaysia highway.
Change to zerone adjustable, soft hard hi low, chose 6k spring rate for front and 4k for rear, set damper to soft. Quite comfortable.
Spring rate means how hard ur spring is, the higher the index theharder it is.
Harder spring stiffened ur car, better at cornering, given that the surface not bumpy, if bumpy, it will jerk ur car off the road surface, reducing contact hence make cornering terrible.
Just my 2 cent.
thanks nyantong... i will try coming weekends...
thanks asrafhaslam... my state sabah have very bad surface on the road... so could it be lower spring rate will be better?
i lived in sabah too bro hahah...have you try disconnecting the battery? sometimes it works..if its not try using nyantong methods.
