myvi with 2zzge engine
tpl
61
3,008
anyone know if myvi can fit 2zzge engine? 1zzfe should be ok for the engine bay but not sure abt 2zzge. anyone know? thx
mag9556
2,770
43
The main problem is.. JPJ will approved?? if not mistaken 1zzfe is 1.8 right...that means 1.3 to 1.8?? can arh?
FVel
716
242
hehehe
He asked whether it is possible to physically fit that specific engine into a myvi, not whether JPJ will approve.
While on the subject, what exactly are the engine thresholds that will fall foul of JPJ's approvals ? I read that thread that Satria95 posted regarding the approval process but it did not detail specific thresholds for engine conversions.
tpl
61
3,008
sorry abt tht. im not sure too from 1.3 to 1.8 will jpj approve or not. but from another forum i was told max is 25% up which is to 1.6liter?
koolspyda
2,889
55
KayEl
koolspyda.blogspot.com
hypotactiaclly if 1zz could fit (bearing in mind if was test fitted; then a 2zz could just)
as for discussion sake;
it most likely means hacking certain areas/firewall(given). one convertion was done in UK on a compact car. one cannot even fit a hand to do adjustments on engine without dropping it.
there car handling was way-way out as even you want to do it for drag; you may be better off with other engines.
mag9556
2,770
43
Sure can not le... 25% as mention is correct ma.. 1.3 max to 1.6 onli except underground way la...hehehe...
K3VEt also ok liao what...somemore Daihatsu Boon also....Good Luck...:driver:
FVel
716
242
Interesting.
Is there any cap on the hp that is allowed when you go from 1.3 to 1.6 ?
I'm very sure (.......actually I am certain.....) there are tuners out there who can swap out a 1.3 and get your car up to a 1.6, but also with the addition of correct performance parts, and the result is hp and peformance significantly higher than say, for example, a stock 1.6 from a Wira....eventhough the car is still NA and still within the 25% allowable capacity upgrade.
Are there additional regulations governing how much performance you are allowed when upgrading to 1.6 from a 1.3 ??
tpl
61
3,008
according to my mech there shouldnt be a prob for engine mounting. they did alot of engine conversion without any mounting problem n thats what they claimed la. k back to the engine, the purpose of the conversion is u all know la myvi really underpower and if i choose a 1nzfe or 1zzfe or a 2zzge its gonna be ard the same cost which i prepared to fork out so might as well get a 2zz huh? hehe.. i wan my car more drivable n more hp/torque n N/A car.
Adeen
2,721
6
kl
my friend with wira 1.3 recently ask the kawal selia in putrajaya there, what was the max can go for 1.3....they said 1.8....so he plonk in gsr turbo...no underground whatsoever....true story..
tpl
61
3,008
adeen thx for the info. still wondering if 2zz able to fit in myvi engiine bay n things like koolspyda mentioned whether its worth the hassle or just bolt on a turbokit.
Adeen
2,721
6
kl
why don't u just go with the daihatsu or toyota turbo engine...
still nice wat....or u wan different from other ppl and become sleeper car..?
mag9556
2,770
43
yaya... Thailand have Vios turbo... 1.5 onli..hehehe
mounting wise.. not sure...
Grixism
432
22
KLTN/VIRGINIA
i think the owner dowan the turbo engine i guess, that's why he opt for other engine such as the 2zz..i know..the feel of torque at low rpm is beautiful
koolspyda
2,889
55
KayEl
honestly in my opinion, putting a 2zz (well built, & tuned & without other upgrades on suspention/braking system) is asking for a death-wish.
there isnt a lot of torque from the 2zz (u can search dyno charts around) compared to some other engine of it class. it has it advantages but if you are prepared to burn your pocket, fine by all means.
slapping any engines can be done locally (many will give you the assurances beforehand but if you are prepared to be guinea pig :proud: (piles of money to get it right).
i would look firstly the base car to be with potential & work from there. Myvi is a nice car (with certain upgrades will just do) but dont think it worth the hybrid project of this magnitude.
YRvi
239
27
Sorry, i'm digging this old thread just to know if any of the daredevils out there has done this conversion?
I'm prepared to sacrifice my 9yr old chasis for this swap. It's just that i need to know anyone that i could refer to.
YRvi
239
27
Hehehe.. anyone would like to share on how to get this done, or direct me to the workshop that have experience of doing this conversion. I think it's about the same like Myvi+4AGE20V since all the supporting arms needs to be converted as well...
D7zul
2,697
848
Shah Alam
Serious? Get urself a myvi extreme n turbocharged it
Save u a lot of hassle.. N i seriously mean a lot of hassle
N save u a lot of money..
Unless u wanna do it as a project car..
But definitely not for daily driving :driver:
A Post Every 5 Mins
just wonderin those who potong spring, how much spring u cut .. measuring from either end,izit i complete circle? or semi circle.. n how low does it get if u cut 1 complete circle or semi circle? wat is the lifespand of yur ori absorber if u cut 1 full circle or semi circle...
thank u sifus sifus out there...hehe
