Myvi engine dies during idle, why this can happen?
Cuppy
36
7
1,508
Selangor
Dear Sifus,
As per topic tittle, this happens sometimes during idle whereby the car dies just like that. Happened once, when i was cruising in a low rpm, less than 2k the car just goes off like that. Unsure what's this about need some handy advice on this to resolve it. Thank you in advance :)
Driving 2005 Myvi EZI
Cuppy
36
7
1,508
Selangor
Haven't try on this yet friend, probably will give it a shot
wira4g13p
28
1,503
idle time or when rpm at 1.8 ~ 2 k? if already rev up maybe ur wyring got problem or ur immobilizer got problem...
Cuppy
36
7
1,508
Selangor
alright 4g13p thanks for your reckon. Say in a situation something is wrong with the immobilizer. How do i diagnose this?
ixeo
4,788
3,080
KL, Malaysia
drive to perodua sc..
tell them to problem..
ask them to scan it with their proprietary obd-ii scanner and see if anything shows up.
When idling is the rev really low? Mine once dropped below 600rpm and died off. Was caused by my clogged DIY OCT and a dirty throttle body. Might want to clean those first.
Cuppy
36
7
1,508
Selangor
@ixeo yup will try on this as well. Thanks for the advice
@izso, last service did TB cleaning using the Threebond, engine flushed, plugs changed to Denso iridium. After that, start to feel the rpm slightly lower like what you said, in my case if the a/c is not running the idle rpm able to reach about 500 and sometimes out of the blues, it just goes off like that. This got me scratching my head thinking what could have been wrong @_@. Mind telling me the OCT don't really get that. Hehe Thanks :)
wira4g13p
28
1,503
last time my vios, go to toyota sc...scan...result no problem...check all wire ... also no problem... last toyota sc suspect immobilizer ...change it FOC...
Good suggestion from wira4g13p. Worthwhile checking.
If you don't know what a OCT is then you probably don't have one so don't worry about it. LOL!
Cuppy
36
7
1,508
Selangor
Latest problem, car dies off even at N position and start to have O/D blinking. Contacted a friend of mine, then after he brought me to his friends shop. The foreman did a diagnostic using some device and reset the ECU. 5minits later the engine dies off again and he re-diagnosed and found out that somethings is faulty at the transmission. Thus, he told me, it is either could be the wayaring or the GB revolution sensor. Only in the evening i can get the actual result.
As for the time being, wondering can GB revolution sensor can cause up to the engine dies of is it? Just wondering, cause i know the revolution sensor for different reason.
Anyone could enlighten on this, thanks sifus :)
xtremeleo
3,247
464
5,183
u have never mentioned u are driving an autobox, lol. thinking cap, ON!! but seriously, have u tried to increase the idle revv tak?
Cuppy
36
7
1,508
Selangor
Ahh...my bad my bad, sorry for that mate. Missing out the most essential information. By the way, it is a 2005 myvi EZI. Didn't try to increase the idle rev, cause too panic already car keep dying thus terus brought it troubleshoot already.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
timing gear jump one key if no fault codes but O/D blinking
transmission problem normally wont cause ur car to dies off
if happened only after changed spark plug..put back the old plugs n test
Hi I'm a newbie here in this detailing forum and i have been reading alot of the posts here. The work done on cars are really good but i have a question if any body can enlighten me.
1. What is the difference between Detailien, KC2, Alienclean, OPC, and other Optimum and alien detailing products?
2. How come most of the post done by this KC2 guy and 1 or 2 others then a flock of many others come and say good work and praise for a good job? Looks like afew guys just do the work all...
