also can, but dont use nitrous, it is too expensive. you can use CO2 instead, you can refill the co2 at any paintball shop for only RM5muahahaha.. naik terus........may i ask u to custom a set for me, as super cool intercooler spray?? lol
not really difficult, as my nitrous kit also can support co2 (co2 & n2o nearly have the same pressure & weight), just need to custom the fogger in front of the intercooler.u can easily diy?
cant use wiper washer nozzle directly? erm..... will there be any danger if put inside the car causes any danger? heat by the sun when park unshaded?not really difficult, as my nitrous kit also can support co2 (co2 & n2o nearly have the same pressure & weight), just need to custom the fogger in front of the intercooler.
cant, as the nozzle cant stand the pressure. we are taling about 1000 psi here. I think no, as the tank is under DOT 3AL spec and comes with 1800 psi burst disk. If over fill, then it can be dangerous.cant use wiper washer nozzle directly? erm..... will there be any danger if put inside the car causes any danger? heat by the sun when park unshaded?
that's why we use fogger nozzle, to control the nitrous pressure and power. Furthermore, nos can only be activated when in full throttle, thus making the intake manifold in vacuum pressure - negative pressure not in positive pressureone thing is dangerous if using NOS in a stock NA engine. Cause I seen a lot of car company keep making manifold that does not look like metal but more of a plastic type. I mean not the weak and useless plastic. What I'm saying is, when you use NOS, a lot of oxygen will inside the intake manifold and if the pressure is to high, it can blow the manifold leaving a crack. And like what all the people comment here, is to expensive to refill and a lot of wear and tear. So is up to you whether you want to use it. Give it a try, sometimes installing new stuff and learning new things can help you in the future, but also there is a cost where you have to pay. hehe. Good luck on the nitrous oxide :D
aiyo, got a lot. no need to go for black market, available in white market.I never heard even in the underground market that sell nitor oxide here in our country. So, I haven't tried that one.
