L5 turbo kit can sustain how much boost.
beyond_4896
278
Currently using L5 kit in my kelisa.
How much baR can tis smaLL turbo can gv? in reliable la.....
joshua963
225
can boost 0.5-0.7 bar maybe... correct me if i'm wrong wor... i also not sure lar... but should be around there..
beyond_4896
278
i mean max boost.. for the turbo de maksimum power boost.
Cuz now i noost 0.9 ma,..
apeng
533
www.kcarlife.com
MY FRENS HAD TRIED ON l2 TURBINE...MAX CAN SUSTAIN 1.6 BAR....
I BELIEVE l5 SHOULD BE AROUND THAT.....
joshua963
225
it all depends on ur driving style lah.. r u a daily driver kinda person or a drag racer... so many factors to take into consideration mah... i guess FC oso would be ur main concern rite... 1.6bar ?? walauweh.. too much ler.. boost boost then terus kena kantoi ler...
white_bird
643
puchong
L5 confirm can sustain 0.9.. sotck boost ma.. mayb max around 1.2~1.4.. depends on ur oil press level also.. but the most important thing is.. ur engine can sustain or not...
beyond_4896
278
huh so lo.. aisk.. i was bolt-on kelisa.
DUno d engine can tahan how much boost leR...
U all replyer is tking k caR?>
white_bird
643
puchong
other i dunno lar.. im drving kenari convert engine.. from wad i know our stock engine has very high compression ratio-10.0:1.. which is not suitable for high boost if nvr upgrade the internal parts..
my suggestion for u mayb u can change to slightly bigger turbine n boost lower.. tht gives u more significant power increase... like td04 9g.. or ct9.. or td025.. or even u can get a hybrid turbo from me.. keke.. not doing promotion lar.. juz giving my suggestion only..
beyond_4896
278
ha?
u also bolt-on owner aaa....?
Hm. if using td04 boost at 0.6. with me now L5 turbine boost 0.9 not same Ka..
white_bird
643
puchong
me convert engine lar...
u know how small is L5 turbie right?
u use on 1000cc engine b4 u rev it oredi start spooling oredi... where got top end power??
apeng
533
www.kcarlife.com
btw,
white bird...
r u selling the same as tong turbine or other hybrid turbine?
beyond,
if u r running on BOT,i guess ur engine is much crucial than the turbine....
since like WB saying...
RHF3 (L5) may be can sustain till 1.2~1.5 bar....
ur engine im not sure can hold the preasure or not....
r u using any mgmt system?
if supply enough should be no problem at all...
happy boosting
beyond_4896
278
now really cant tahan liao.
Need bigger turbine than L5 turbine.
got any intro?>
hi bro's, few questions here.....
one) other than rev cut, wat else does an rsm can overide??
two) can air/fuel ratio be set in it??? if yes, whats the use of afc then??
three) can the a/f ratio set by ourself or must do at shop?? if yes, how much will it cost....
i thank you guys before hand, even if u just go through my post.....
