Knocking sound when reverse gear
ajis
18
1,503
kulim
Hi sifu2 n frens,
Im driving 2010 Vios E spec and my problem is bout some knocking sound :confused: .Sometimes when im moving my gear from D@N to R position and when the gear is lock there will be 1 'knock' sound from front of the car :mad: . I try to search for it and i think it is from front driver side brake area :hmmmm: I did try to press hard the brake cause i thought the sound might be sound from the slip pad with the disk but it still happen. Can someone please let me know what it is?:adore: TQ :wavey:
Neo_
227
52
528
Bro,go and get ur suspensions checked. or remove your backseats and see whats happening there.
this is a quite common problem with vios. that sound which comes specially when u go into reverse gear .
my friend had this problem.
ajis
18
1,503
kulim
thanks bro...i'll check it out...:itsme:
What was your friend's problem, maybe can pin point the problem instead....
Neo_
227
52
528
he had 2 problem.
some parts from the rear seat area was loose.so when they took it out.fixed back everything . the sound went off.
the shop tightened the screw from the rear absorbers.i dont know which one to be precise. but this was the only info i got from my friend.
i only was there forawhile when they were trying to diagnose the problem .
he had 2 problem.
Thanks, rear absorber probably from the top near the rear seats. TS can do both at the same time....:biggrin:
ajis
18
1,503
kulim
thanks guys...i'll check the rear top absorber nut too...:itsme:
The Bank of Singapore has hosted a golf tournament for 2011 at KLGCC, and are set to replicate the success from the 2010. This tournament is a well organized event, offering a variety of golf courses. The league is targeted at corporate players, spanning across various industries, allowing them the opportunity to mingle and network.
For the KLGCC leg...
