WTA: BT 20v knocking sound....
MR. TOM'S
hi to all,
I've got a problem wif my BT engine..
Its a knocking sound when i pressed my throttle pedal
too bad when the air-con is ON..
my BT engine still in stock...just using splitfire cable plug, iridium plug, hks open pod and AFR, straight flow exhaust.....the rest is stock
I try refer to my mechanic...tried retard and advanced my distributor..but still the same....changed oledi ECU, plug coil, petrol filter, cable plug, plug (borrowed from fren)..but the result same after tunning....my mechanic suggest me to upgrade the injector...
As i knew that knocking prob very dangerous to the engine and need to solve it fast...
So the Q are.....
How to solve this problem???
What i need to check???
Any1 from here had a same prob wif me...???
What suitable INJECTOR tat can fit my 20v???
Can 20v be tune using same as what proton and mitsubishi done ??? (dono what machine name..but when i used my wira before had done the tune and its work very well to my 1.5 wira)
SO to all sifu outthere...gimme some ideas and opinion regarding my problem.
Thanks:adore::adore::adore::adore:
where do u think the sound came from?
Top? Block?
CAM pulley ok? VVT ok? checked?
my 2 cents....:hmmmm:
try you go to Dyno... after dyno then you will know... By your situation, the stock injector is more than enough. 315cc side feed injector. That why i don't think it is knocking sound.
Dyno won't solve the problem at all. You get the the power reading and AFR reading from the Dyno.
By the way 20V injector is 295cc NOT 315cc.
Engine Specifications and Comparisons
Don't provide misleading information if you don't know or not sure.
i don't know why, you just reply all the topic either you know the answer or not.
To show ppl that you know something? Don't do that if you don't know because you'll be laughing stock. Even worst if they try what you've suggest and cause damage to their engine.
Please do you homework. Although everyone free to voice up their opinion on forum but at least make it a useful suggestion.
hi to all,
So the Q are.....
what you can do it try to retard your ignition distributor timing by a few degree.
If it's still doesn't solve the problem, check the fuel pressure. Low fuel pressure also can cause the pigging problem. Make sure the fuel pressure is around 40psi at WOT and nothing lower then 30psi for ideal.
Beside that, pls check your engine operating temperature also, higher operating temp also can cause pigging. it's premature ignition due to heat, high compression or lack of fuel.
That's right .. last time my engine had knocking sound because of my fuel pressure was too lean .. (that's whut happen if u install the afpr from accessories shop.. they just know to install)
I tried to retard the distribution....better a bit..but seem like in mid RPM my engine dont have power at all....like "sebu"..happen when rpm 3k to rpm 6k...
How to check the fuel pressure???
40 psi at WOT???? WOT????
My engine operating was normal.....
Sori coz im newby......:adore::adore::adore:
you need fuel pressure gauge to check the fuel pressure.
WOT = Wide Open throttle (Full pedal)
Engine operating temp is the water temp.
yes, the injector is 295 cc, my mistake!
sorry.... Dyno there can get to check whether the AFR is lean or rich, but i didn't said it will fully solve out the problem. Normally the stock engine won't need to replace injector as him formen said ma. Retard the timing is good idea and check the fuel pressure is important, but need the tools le.
I not to show i know something, but just to share ideal. If it not suit you or not useful suggestion, then you can try edit it out what. Share idea only no hunt. - Peace -:burnout:
beside checking your fuel pressure...you can also install A/F Ratio meter...tom's got one for sale...
it will indicate your AF = Air Fuel ratio lean, stoich or rich...
got white smoke came out for tail pipe or not ?
have you check and listen is there any sound came from conrod bearing...?
Have you check the rubber of the engine mounting ? Just my suggestions because you said knocking "sound". :proud:
Knocking sound that he mean is detonation in combustion camber. That mean premature combustion.
thanks for ur info guys.....appreciate a lot...
will try to ask and suggest my foreman this weekend
may i know can 20v engine be tune wif MIT tunning machine...like proton cars do..???
Have any1 tried before...just wanna ask...
And actually how to tune 20v engine....isit oni tune the distributor???
I heard tat 4 throttle can be tune....??? where n how much??
Thanks guys.....:adore::adore:
20v is OBD I controlled engine .. u will not be able to "tune" it normally .. OBD is a self correcting ECU as its name suggest .. On Board Diagnostics
whatever u try to change in tuning the ECU will try to revert back to the pre-determined factory settings .. the only way u can TRULY tune it is changing the ECU itself ..
regarding the tuning the 4 throttle .. YES it can be tuned .. each throttle opens individually and therefore has different vacuum pressure sucking air in .. to tune that vacuum u will need a device that can detect the pressure of the individual throttle at certain RPMs .. hopefully yours has not been meddled with coz that will oso cause incorrect AFR going into engine ..
sifoo EG9 ... dont laa so marah ppl .. hehehehe
i oso wish i have a 20v laa now :bawling:
discuss wit few of my frens...wat did EG9 said is correct...worst case ever is the conrod bearing...but if not mistaken conrod bearing will be heard the knocking sound once u start ur engine...in ur case i dun think it is lor...the plug tat u use is in the correct heat range??
dun shoot me oso ah bro EG9....
wah...conrod bearing....dont say tat wor...so afraid r...
I thinks its not my conrod bearing...but knocking like not enough fuel..like wat my foreman said..
If i send my car for dyno session...what the result tat i can get..??? Anything tat can solve my problem.....will they set my car and solve my problem??? If yes i'll try..
How much for the dyno...??? any recommended shop/place?????
Do u mean tat fuel pressure gauge at fuel pressure regulator can show either my fuel rich or lean...?????
when i pressed my pedal..dont have white smoke but a bit blue smoke i think...isit normal....???
p/s SO SORRY GUYS FOR ASKING A DUMB QUESTION....IM A BIT NEW AND REALLY WANNA KNOW MORE ABOUT 20V...:adore::adore:
hOPE U ALL CAN GIMME MORE INFO
MILLION THANKS FOR THOSE WHO HELP....:adore::adore::adore:
I won't simply shoot..we are here to share and learn.
basicaly conrod bearing knocking sound is totally different from pigging or knocking.
In this case I don't think it's a conrod sound, it that is conrod sound, it will become louder day by day and peformance will reduce termendously.
don't worry.
