how to upgrade my mived-md v6 6a12 to bolt on turbo
garage@inc
10
hello ....my engine now is mivec-md 2.0 v6 would like to upgrade to twin turbo
what are the things i need to install :banghead:
Dbass
156
Ampang, Selango
Standalone ECU,
Turbo,
Boost meter,
Intercooler piping,
Piston Turbo,
Metal gasket
Exzos temp meter
Fuel Pump Walbro
garage@inc
10
if i used extractor/banana from v6 twin turbo can?? or not match
My car is Civic EK3
The problem is got abnormal sound at from arm then
1. At 1st, I changed all ball joint and the noise still same
2. Few months later, I changes upper arm bush and the sound reduced 50%
3. Few months later, I change lower arm bush and the car run steady with new bush but the problem is the noise increased
what will the problem be?it is
1. Absorber??? --->my absorber no leaking or the absorber bush damaged??? --->is this bush sold in market?
2. Absorber shaft...
