ICE Upgrade.
mosesmk
165
32
Selangor
Dear All
Anyone done ICE upgrading already? Am want to install amplifier in my trunk. The problem am been searching for the best route to place my power cable. It look like there is not access via firewall. I been googling around and some of lancer user pull the power cable thru the fender which is for me nit really a good way to do so. Any advise?
Thank You in advance.
Firewall no access? That's new. The wiring and all - how does it take power then? I suspect there could be a grommet you could modify ?
Yah! how are the wire harness from engine going in to the passenger compartment?
mosesmk
165
32
Selangor
There is one big grommet goes to the center of dash. as usual i will try to kept the original wiring harness alone. what i mean it there is not spare grommet. maybe my search no thorough and yet found the way.
Well, if you're willing to go to the extreme, add a spare battery at the back to power your sound system. :biggrin:
Anyway, the other alternative would be to drill a hole in the firewall and seal it with the necessary power wire and a rubber grommet. Not too difficult to do
Wah! another battery will be much more work woh! Alternator can charge 2 batteries?
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
drill a hole at firewall is easier but there must be existing gromnet u can used.some make will have grommet behind fender nearest to the driver so its closer to the fusebox.
2 battery can be done but better upgrade the altenator too.just like 4x4 with winch,some go for 2 battery setup but their under hood space is big so most of the time no need to pull cable until the rear
Sixth Element... i'm sure those that read taiwan or hongkong
car magazines came across this in the magazine..
so anyone using it ? comment ??
not sure if anyone posted this b4 ?
isit the same concept as those magnectic thingy ??
or is this another gadget with nice marketing plan ?
hahah..
anyone know is there m'sian dealer / distributor for this
product ?
application in different part and location in car...
