How to installed Tulang Ikan?
Aura
I am a bit fussy to spend on that pricey 'boost controller' and some says that the alternative is tulang ikan..How to install it? And is there any bad consequences if we installed tulang ikan? Making enjin rosak so soon?
no komen on that coz i'm using it 3 control my boost plus buang my boost cut....
Aura said:
So if no problem with your engine, how to install it?
before ur T hose actuator put ur flowerhon fishbone.
must remember it will not remove the boost cut as it still remain boost cut.
With Fishbone:
Watercooled turbo boost cut tested only go 1.0bar
Oil cooled turbo cut tested only at 1.3bar
See at GTTikuning pics there goes the fishbone.
With Fishbone:
ya lor...
if want 2 remove boost cut u need a T hose,one way valve n tulang ikan....
just plug in ur T hose at the map censor ...
then install that one way valve n lastly d fishbone.....
i'll up d pic later.....
cateyes said:
With Fishbone:
Hi cateyes,
Whats the difference between watercooled turbo boost & oil cooled turbo boost? I assume in any turbo-charged car only 1 of them can appear at the same time right?
For gtti, which 1 applies? :willy:
cb70 said:
Hi cateyes,
depends...
some GTti run on water n some run on oil...
like mine is running on oil.....
gtti_kuning said:
depends...
I didn't know that before..I'm just my car every weekend and change oil every month..That's all I know..
cb70 said:
Hi cateyes,
Just simple and depends on luck.
Water cooled turbo have water hose to radiator and oil cooled turbo just like Gttikuning pics.
gtti_kuning said:
waaa....
must refer pomen first aa?
last time i install never refer pomen also..
just installed my self only....:D
what kind of tulang ikan u install??? ikan semilang or ikan siakap?? :biggrin: ...
guys..i'm installing a boost controller myself, I wonder where to get extra vacuum hose?
which type is ur boost controller?
U want to buy a new vaccum hose or ?
its an electronic boost controller..wiring done..just need to get vacuum hoses to connect the IN/OUT..coz the stock OEM hose connected from the turbo to actuator is TOO short..
any idea where can I get reliablie hoses?
adviseable to get the black vaccum hoses as the stock.You can get it at any spare parts shop.Make sure u bring the sample or shown him the hoses.
Some might used silicon hose.depends on u to choose either the stock or the silicon.
thanks man..need some bigger sizes one as compare to the normal ones..will have to scout around.
Thanks again!
