my car oso no pickup at all..., they said maybe coz my clutch plate kong..
then i change once... but still no improvement on pickup. sign!!!!
fyi, im driving plotong putra.
How about rims,are u using heavy rims 16',17' inch.That might be the factor.4-2-1 extractor gives better perfomance then the oem ones.I'm using in my iswara 1.3 and can hit 160kmh.Check ur clutch plate,tuning,timing belt etc....
putra no power? cant be la.. wat modi u hv so far?
First thing is that when you drive your wira at 170 it would be kind of dangerous and handling problem too... make sure you got pair of good condition set of tyres and brakes.
145 seem little low than expected... a wira can easily goes up to 150-160 without any mod ......maybe it just your car is heavier (lots of stuff in trunk) use of heavier and cheap quality oil ( such as 20W50 or such ...) and poor spark plugs
to get a higher speed, lighten your trunk first ... then get better engine oil 10W40 or 5W30 .... new set of plugs.... there you go .. it should get better now...
I did too have a wira 1.5 auto 97 . Having the same problem as you. So I change to Platinum Spark Plug and then 10mm plug cable and my care went to 160. Using a 13 inch ori rim but changed to a better tire, Falken and dunlop LM 701 cause I want to make sure I have a better grip on the road... :bath:
I need some advice..
Few days ago, my exhaust emits white smoke while driving for 5 minutes of
maintaining speed at 140km/h~150km/h range.
If the speed is reduced to 120km/h~130km/h range, no more white...
Need to ask you guys questions again if you dont mind...There is a "Snow" button besidesthe seat heater buttons. What is this for?... The reason I ask is I am worried about my car. I recently loss a...
