Isn't it illegal to do 4WD transplant?
Normally they do front first then after get approval then do the rear part....
You mean install the 4WD gearbox first and endorse? Then only install the driveshaft to make it 4WD?
if unker convert 4wd, jpj wont know cos ori vr4 is originally 4wd ma. unless they look at the geran then kantoi la
The gearbox is the same unit whether fitting in as 4WD or 2WD. For 2WD, have to weld the rear drive so power transmit to front. To have 4WD have to install the long shaft, rear drive shaft and also the petrol tank have to be changed to accommodate the long shaft running to the rear. Of course the rear assembly all have to change as 2WD rear is torsion beam...
---------- Post added at 09:45 AM ---------- 6 hour anti-bump limit - Previous post was at 09:43 AM ----------
Your 6A12TT was 4WD right?
Its a craaaazzzzyyy world out there.
no 2wd only, locked from 4wd - 2wd but running on evo gbox la.
the world is not chee sin maa, drivers r
Oh, meaning like having the gearbox but the rear parts to drive the rear wheels is removed?
Yup, when we buy half cut you get the front only, so even wire harness have to join below driver seat.
Rear not touch for undercarraige.
If 4WD then got to buy rear half cut too, then you get the rear parts....
Rear cuts are usually sold cheaper right? But the demand for rear cut is not much I think.
Similar threads | |
