High Idling issues on evo1 engine with Microtech?
wongsl
65
1,508
:embaressed_smile: problem solved. Found the idle adjust screw on intake manifold near throttle body.
normality78
3,052
23
5,138
JB
woah.... this is one big time ICE sifu wor....
wongsl
65
1,508
aiyooo.. you know I'm learning about car mods la. Don't tekan me here la :emoticon_U: Now headache with this high idle problem. I'm scared is my wastegate acuator, then have to spend a lot of $ liao :sad_smile:
I heard your new engine in and dynoed already. When wanna take me for a spin? Let me know what G-force is supposed to mean la.. :_:
normality78
3,052
23
5,138
JB
wahahaha. u already very knowledgable in car modding mar. i whr got tekan u wor.
you're using external wastegate huh? I dont see the connection between idling problem and actuator fault. i maybe wrong but wastegate was merely regulated your boost on your request psi but not idling as idling does not produce any boost. Its more like a leak issue to me
dun tease on me on my car la... i know my car canot make it one. the dynoed was not perfect yet. runs into a few issue
wongsl
65
1,508
nope. using stock wastegate actuator with electronic boost controller. no $ for external la.
btw, I found the problem to high idle liao. There's a idle screw on the intake :embaressed_smile:
Hello sifu's,
I have a question here. I was informed that removing balance shaft lightens the engine. No doubt the vibration increases but does the performance increase too ?
Is there any side effect ? Can we get the timing right or not ?
There is supposed to be 2 balance shafts ? can we remove both ?
Another question is regarding injectors. Instead of adding additional injectors can we use the RX7 injectors for 4G63T. What are the difference. RX7 is supposed to be 1.3 rotary...
